Question about Samsung Televison & Video
Blank screen on my sp46l6hx but the lamp fires up ??? and i can hear the sound?????????????????????????
I have the save problem !
c.klipfel@wanadoo.fr
Posted on Jan 23, 2010
Screen going black
try to replace the inverter if not getting image is the lcd cable or the lcd
May 04, 2012 | Computers & Internet
It powers on but the power button blinks an the screen will not light up an i hear a popping an crackling sound in the back of it its a very faint sound
You should check the lamp. The cracking sound is the ballast trying to fire the lamp. The part number is TY-LA1000 and can run up to $275
Bill W
integrityhomeworx.com
Mar 23, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Timer/standy light ison and screen is blank when
When did you replaced lamp last time in your Sony KDF-42WE655 tv?
It sounds lamp got weak, unable to fire up and need to be replaced.
Let me know your findings to help you out.
Thanks.
Mar 14, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sound but no vision, black screen
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 25, 2009 | Sony Televison & Video
Samsung DLP TV HL-R4667W. When turned on, the TV comes on normally. Within about 10 - 20 seconds, the screen goes blank, can hear the sound for another couple of seconds, then can hear a relay trip, and...
Those lights flashing mean the lamp is the issue. You need to test it with a meter. If the lamp tests ok then it may be the ballast is bad and that is what powers the lamp.
Oct 12, 2017 | Televison & Video
Blank screen when booting a t30
You could have a faulty CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 07, 2009 | IBM ThinkPad T42 Laptop
My tv screen on my samsung rear screen projector has gone blank(black screen although sound is still clear.
Do you hear a motor spin up and a clicking sound as the tv is first turned on, if yes, You need to look behind the set and see if the lamp is still illuminated, if not replace lamp. Good luck.
Jul 07, 2009 | Samsung Televison & Video
Blank screen
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Mar 11, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
We have sound, but no picture
could be the relay transistor or diode close to the relay in the power supply
Sep 29, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
