Question about Oreck XL Ultra Bagged Upright Vacuum
How do I replace the brush roll on my oreck xl??
    Problem Solver:
  • 4 Answers
Turn the vacume upside down. Remove the 5 screws on the bottom plate. 3 are near the brush roll, and 2 are near the back. Remove the bottom plate. take the belt off the motor end. pull up on both ends of the brush roll. Put new brush roll on making sure that you put both ends to the new position, not old. ( it is marked on one end, and there are marks on the side that goes up so the can match.)(If putting back the old brush roll you can switch to the old position. After a year or two you can switch the new brush roll to the old position.) Put the bels back on the motor shaft and then stretch and start the belt on the brush roll and rotate the brushroll by hand untill the belt is all the way on.
put the bottom plate back on and tighten the 5 bottom screws.
Posted on Apr 24, 2009
  • Maxumark Apr 24, 2009
    How to…an Oreck DIY guide: All other models not including XL7.
    Before attempting any DIY servicing always ensure the machine is turned off and unplugged.
    How to Replace a corner brush:
    • To replace a corner brush you will need a star head Phillips screwdriver.
    • Remove the base plate of the vacuum by unscrewing all 5 screws. (see below)
    • Remove the single screw securing each corner brush and remove the old corner brush.
    • Affix the new corner brushes by replacing the screw and then replace the base plate.
    How to Replace a Roller Brush:
    • First undo all 5 screws that secure the base plate to the machine and remove the base plate (see above)
    • Also unscrew and remove the belt door and release the belt. (see How to replace a belt below)
    • The roller brush is then ready to lift out.
    • Replace the new brush ensuring that the bearing blocks match on both ends – See warning below.
    • With the brush slotted back into place replace the belt, belt door and the base plate ensuring all the screws are firmly in place.
    NB: Do not over tighten the middle base plate screw, as the machine won’t tilt.
    Lift Roller Brush out
    Belt
    WARNING:
    Ensure when you replace the brush that the bearing end caps match on both sides. On the top of the bearing blocks you shall see little grooves. When slotting the roller brush back in the bearing blocks must either have one groove on each side, or multiple grooves on each side. On the side of the blocks you may see some text as shown below this will help you match the grooves.
    If the grooves are NOT matched the roller brush may not be level causing damage to your machine.
    Inverting the Roller Brush:
    Inverting the roller brush helps to prolong its life by swapping the bearing end caps over so that the bristles become closer to the ground surface.
    To invert the roller brush you first need to remove the roller brush as detailed in How to Replace a Roller Brush above. Follow first 3 steps before moving onto the step process outlined below:
    • Look at the bearing end caps on end of the roller brush. Where the multi groove appears on top and the word ‘New’ is written on the side, invert this bearing so that it will be this end that is slotted back into the machine. The top of the bearing, which will be facing the floor, should now have a single groove on top and the word ‘Old’ written on the side.
    • Ensure BOTH ends of the roller brush now have the single groove side of the bearing end cap facing upwards (the side which will be nearest the floor)
    • Replace the roller brush back into position and reassemble the belt, belt door and base plate, fastening all five screws back into position.
    Old Setting
    New Setting
    How to Change a Belt:
    • Located on the bottom of the base plate of your machine should be a spare belt.
    • To remove the old belt either remove the side panel of the machine by sliding the door forward as shown below. This will require a star head Phillips screwdriver. However if you find this too awkward you may like to try removing the base plate also, as detailed in How to Remove a Corner Brush above.
    • To attach the new belt, hook the belt over the motor spindle and then stretch it towards the wheel. With an edge on the wheel begin turning the wheel slowly to centralise the belt.
    • Once the belt has taken and is firmly attached replace the side panel and/or the base plate.
    Remove single screw in side panel
    Spare belt located on the base plate
    Rotate the brush wheel
    Replace side panel
    Slide door forwards – try using the screw driver to help pry open
    Loop over motor spindle and wheel – do not loop over plastic spindle.
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
SOURCE: Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 25, 2008
  • 206 Answers
SOURCE: installing roller brush for oreck XL 21
uh, probably not sure what the issue is, but
1. unplug unit.
2. Remove the multiple screws from the bottom of the unit.
3. remove the bottom baseplate (usually black)
4. the brush roll is now visible, and the belt should be around it.
5. Pull the brush roll away from the unit, and disengage the belt.
6. Replace in the opposite order. Make sure that baseplate fits properly to insure a good seal. Also watch the bumper (rubber part that is wrapped around the unit) to make sure it is properly seated.
7. Handroll the roller brush before plugging in. Make sure it moves freely.
8. Run unit, may get a slight burning smell, but if this continues for more than a minute - turn off and inspect the unit. Brush roll requires a short burn in time, on initial build, factory accomplishes this during test procedures.
Posted on Jul 30, 2009
  • 172 Answers
SOURCE: I have to replace the motor brushes in my Oreck XL
If it's an AC induction motor there are no brushes.
Posted on Aug 12, 2009
SOURCE: My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Posted on Nov 06, 2009
Why does my Oreck upright. Acumen keep shutting off after a couple of seconds?
Atek,
Sounds like you have one of the Oreck's that has a sensor that looks for the brush turning and you received the wrong brush. Look to see if there is a metal ball embedded in the wood about a quarter or a third of the way down from the end opposite the belt end. If there is not the metal ball, you have the wrong brush roll. Getting the proper brush roller should make all the difference for you. Hope this helps!
Feb 24, 2015 | Oreck XL Platinum Pilot Bagged Upright...
Why won't my oreck xl upright brush turn
You could have a couple of problems, the first and simplest to fix is a broken belt. You can check that by taking the screw out of the side door of your vacuum and take the door off. You should see the motor shaft towards the back of the unit and the pulley for the brush roll at the front of the unit. If your belt is broken you can just replace it with a new one and put the door back in place and replace the screw and you should be back in business. If the belt is not broken and is around the motor shaft and brush pulley, you could have bad bearings on your brush roll or you could have hair and lint bound up around the bearings of the brush roll. Depending on how long you have had that brush roll in your vacuum, you might want to check into replacing it. If you have to take off the bottom cover to get to the brush roll, you need to take out 5 screws that hold the bottom plate on. If you take the brush roll out make sure you note which way the marks on the bearings are showing. If you have several "hash" marks showing that is the setting for a new brush, if only 1 "hash" mark is showing that is the setting for a used brush. If you have had it for a while and you find it on the new setting and the vacuum has not been "pulling" itself while vacuuming then you probably should turn the bearings over to the used setting and that will lower the brush closer to the floor and should start pulling again. Hope this helps! Sorry it is so long.
Sep 07, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck brush only turns a tiny bit and belt pulley get hot belt not turning much either
If your brush is not turning properly then you need to check the bearing ends to see if there is any hair, string, or thread wound around the brush shaft. If there is and you can remove it, that might fix your problem otherwise I would suggest getting a new brush roller.
Jun 30, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Suction problem
Probably have a clog some where in the base and that is what causes it to throw stuff back out.
Apr 04, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Changing the belt
Always make sure your machine is unplugged from the outlet before replacing the belt.
Newer Oreck uprights have an access plate on the right hand side of the base (as you're looking at it from the front). Remove the one screw from the access plate and slide it forward. Snake the new belt around the brush roll pulley and then strrrrrrretch it back to the motor shaft. Replace the access plate.
If your model does not have an access plate; turn the machine upside down, Remove all screws. Lift the bottom plate off. Observe the position of the brush roll ends, One side of each end cap will have several notches cut into it,this is the 'new' side, the other side is smooth, this is the 'old' side. You can reposition the brush roll the the 'old' side if your bristles appear worn down.
With the brush roll still removed; place one end of the belt over the motor shaft first, place the other side of the belt around the brush roll pulley and stretch the brush roll forward until it is back in place.
Spin the brush roll by hand before replacing the cover to ensure the belt is not pinched.
Replace to cover.
May 16, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Installing roller brush for oreck XL 21
1. unplug unit.
Jun 30, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck Commercial XL 21
Check that the beater bar is completely clear of thread, this will bring the brush roll back to normal. Also check the sides of the brush roll doesn't have anything such as thread or thick string at the sides.
Jun 16, 2009 | Oreck XL21 Bagged Upright Vacuum
Replace belt on my oreck xl
May 08, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL9100 Brush clogged with hair
The pulley will turn off, then the end will pull off. Some of the replacement brush rolls, the pulley may be pressed on and may or may not come off with out ruining the end.
Apr 22, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
1,789 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
