Blad won't spin
I borrowed a QEP 7" wet tile saw from a friend. I have filled the well with water, but when I turn on the power I hear the motor but the blade isn't spinning. What could be the problem? Thanks!
  • htppmd Apr 22, 2009
    thanks for your help. It turns out there was an old peice of tile in the well that had jammed the saw. once i cleaned it out, it works fine. Thanks again!
  • 3 Answers
If it's the small, stationary saw they show on their web-site, the only thing I might suggest is that you check to make sure there are bushings in place on each side of the blade (is the arbor spinning, but the blade not?). Otherwise, since it's a direct-drive unit, there are no belts, etc. Some small saws have an arbor-lock on the motor, to help with tightening the arbor-nut. If this is stuck engaged, it would keep the motor from turning, even though you hear something. Not familar with this brand though, and their PDF manual leaves a bit to be desired. Hope this helps.
Posted on Apr 21, 2009
I have a QEP 7" tile saw. When I plug it in and press the switch, it hums-blade does not spin. (Note: not ready to cut tile yet, so no water in the bottom) Does anyone have any ideas on what's wrong?
Sounds like a shorted motor,or a dead spot on the armature. Try rotating the blade manually with no power first, then plug it in to see if it starts up. Don't let it hum for more than a second at a time, or it's sure to burn up the motor our trip the breaker.
Feb 12, 2016 | Qep Saws
Where do you put the water?
Most wet saws have a water tray below the table area. The blade moves thru this tray and gets cooled and lubricated by the water
Mar 06, 2015 | Qep 60087 Table Tile Saw 7" Wet
Switch won't work
Take it apart and fix the switch or put a new, different switch in the circuit. May just be a broken wire. Jack
Nov 23, 2013 | Roberts 10-22500 QEP 7 Tile Wet Saw
TILE SAW WON'T SPRAY, PUMP AN MOTOR RUN CHECK FOR DEBRI HOW DO I CLEAN TUBING TO SPRAYER I THINK IT IS CLOGGED
Make sure pump is submerged i water
Remove tubing from pump discharge and see if pump is pumping water/ If so your tubing is clogged between pump and saw. Remove tubing and rinse out with hose.
Nov 28, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
What direction for blade rotation
The top of the blade spins toward you, but maybe you are asking which way the blade should go? If this is a tile saw, the teeth are tiny bits of diamond and will work in either direction. If this is blade with visible teeth, as for cutting wood, the points of the teeth should be toward you on the top of the blade. Good luck.
May 26, 2012 | Qep 60087 Table Tile Saw 7" Wet
The nut that holds the saw blade on is flat like a washer. I can't find a tool to remove it. i want to change the saw blade.
Some of those nuts had 2 holes in them and there is a special tool that fits in the holes and you turn the tool to unloosen it.
Mar 16, 2011 | Wet International Q.E.P 4 inch Portable...
Where does the water go?
Generally you can take the top off and the water goes in the bottom just under the saw. As far as the level goes they usually have a fill hole that when filled up all the way it will start to run out. If not, just make sure the blade is in water for about an inch or two.
Aug 03, 2009 | Wet International Q.E.P 4 inch Portable...
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
