The on/off button on LCD Samsung Tv.
When it is turned on the switch keeps clicking it self on and off quite a few times before the picture comes on.
TVCHIEFTAIN
SOURCE: samsung lcd 40" does not switch on immediatly
Check for bulging capacitors in the main power supply...the tops of the caps will be swelled. Good Luck.
Posted on Sep 04, 2009
SOURCE: Sharp tv standby button wont switch on
have the same problem .please help.
Posted on Aug 31, 2008
SOURCE: samsung 42'' lcd keeps switching off and on
I have the same problem
Posted on Dec 23, 2008
  • 4 Answers
SOURCE: Samsung LE40R7 LCD TV Attempts
Possibly due to the main inverter panel, take the numbers off and price one up they vary from £50 upwards
Posted on Apr 08, 2009
SOURCE: MY SAMSUNG T.V. CLICKS AND WON'T SWITCH ON
I can't take credit for what I am about to suggest. Another user on this site already figured it out. The power board does not have to be replaced. The problem is faulty capacitors on the board. If you are handy, you can replace them in short order. The bad capacitors are the 1000micro-Farad, 10V capacitors. The tops of the capacitor should be flat, but a bad capacitor will have a slightly dome shaped top. It looks swollen at the top, but it's subtle. The user that originally posted the fix reported that some bad capacitors will also have a brown liquid oozing from the top. Anyway, I had the same problem and I replaced two capacitors this weekend for less than $4. It's worth a try if your unit is out of warranty because if you have a repair man come out, you will take a drumming.
Posted on Dec 14, 2009
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Led tv no picture
Sounds like fluorescent tube has gone, but you say this is LED? Newer tvs are LED. What you have, may be LCD, in which fluorescent tubes were used. You have no recourse.
Feb 12, 2014 | Televison & Video
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung ln t4665f : Power Light On , No Picture : Clicking Sound
could be just a few bad capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1 each
value is 1000mf at 16volts usually replace four of them
Aug 20, 2009 | Samsung LN-T4665F 46 in. LCD Television
Tv wil not turn on just keeps making a clicking noise
ur relay keep try hard to turn tv on that u hear clicking noise.
+5VDC is leaking! open back cover,check power supply board.
1000uF or 2200uF capacitor is popped open or leaky.replace with known top quality capacitor.do it ur self repair will save u $200.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Power won't come on- constant clicking loop instead
My T.V. did the same thing and it was due to bad capacitors on the power supply board. the tops of the capacitors were bulged, once replaced it worked fine. It involves sodering in new capacitors total cost $30. that includes buying the sodering tool. Keep looking around on line someone had pictures step by step how to do it.
Mar 26, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Tv turning its self up?
is it showing it turn its self up on the tv by the bars or is the sound just getting louder by itself
is your remote a learning remote and does your tv have a preset volume that when turned on its to goto
if showing by bars one of the buttons on your remote is stuck or needs cleaning and
quite possibly getting an outside frequency thats interfering with your remote frequency
but if no bars are showing the service provider company i noticed my self there tv programs are flauxing in sound for some reason this to me gets annoying
May 29, 2008 | Olevia LT27HVX 27 in. LCD Television
Televison & Video Logo
803 people viewed this question
Top Televison & Video Experts
Electro Med Services...
