Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune shutdown
When i put the washmachine in RINSE 1 position the machine began fill with water but after 15 to 25 seconds went shutdown. I call a Maytag specialist and said in need to buy a control panel . We buy the control panel but dont resolve the problem
  • 58 Answers
You need to first check your water inlet hoses & make sure they are not kinked or plugged.(verify by disconnecting hoses & opening to make sure water flows. If ok. Then check for cold water operation at fill valve. If no cold water after a few seconds then the problem is the water fill valve. If this doesn't help. Post findings for further troubleshooting.
Bill
Posted on Apr 22, 2009
I have a Maytag Centennial washer, model number MVWC6ESWW, when I start the machine, it immediately starts agitating and adding water simeltaneously. At the end of the cycle, the clothes are soaking wet,...
I had the same issue. When I started the machine it began agitating and then began to fill as if it is beginning the second rinse cycle - well I think it was.... SO, I threw in some towels and began the cycle at the second rinse part of the cycle. Low and behold, the next load started and finished just fine.
I hope this helps. This is just one of many issues with this machine, but luckily I haven't had to call the repairman yet! They all seem to revolve around the thing being out of sync.
May 01, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune Washer MAH3000AWW
This is out in cyberspace Cant remember what or where. Do a search for "Maytag Neptune shuts off"
Sep 17, 2008 | Maytag Neptune Washer
Maytag neptune,shuts down within 10 seconds after start button is pushed
If it has worked for a year and your able to choose different cycles with the same result. It seems to functions with one common element failing. If the control unit cant detect how full the machine is with water it will shut down. Sounds like a water problem steming from your pressure switch. Not sure which model you have but usually it will sit on the water pump or under the console with a clear hose if under the console. If so a quick test of attaching an ohm meter set on continuity then blowing lightly to see if under pressure the switch reacts by closing if it doesnt then the switch is bad.
Sep 16, 2008 | Washing Machines
Neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Aug 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH4000
Are you getting cold water to fill ?How is the water pressure?Timer maybe at fault here.
Jun 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Shutting off early
Check out http://www.maytagfrontloadsettlement.com. This sounds like the same problem many other Maytag customers have encountered (including me).
Dec 07, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune stops during rinse cycles
from what you say it doesnt sound like a water valve. does it fill to correct level the first time round?
Mar 27, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
