Question about Sanyo HT32744 32" TV
Remote Control Wondering how to program the remoot control unit for using DVD and VCR?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
I think no prog. required for using DVD OR VCR. JUST set tv to AV mode connect appropriate wire from dvd to tv in audio video socket. good luck.
Posted on Sep 23, 2007
SOURCE:
How to operate with remote control
VCR Remote Control Buying Guide ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls
Finding a suitable VCR remote control to operate a combo unit involves finding a remote that supports the functions of each component of the unit. The key to ...
REMOTE CONTROL MANUAL Synergy V - RCN
help.rcn.com/pf/12/webfiles/files/ONNET6907/remotes/RC.../index.htm
Jump to Operating In VCR mode - Your remote control is designed to operate many functions of your VCR. To select your remote's VCR mode:.
Program and Operate Your Cox Remote Control
www.cox.com/business/support/.../article.cox?...
Cox CommunicationsApr 28, 2015 - ... on how to operate and program the buttons on your remote control, select from ... Index of Remote Controls ... Program TV, DVD, VCR, Stereo.
VCR remote control codes ' FiOS TV ' Residential Support ...
Jan 14, 2016 | Televison & Video
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
Remote code
u cant unless u change the codes every time u wanna use on the vcr/dvd and change when u wanna use on the tv my advice get another remote for the vcr/dvd
Jul 19, 2013 | Insignia IS-DVD040924 DVD Player/VCR
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works.
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Wats the remote code no. for vinverth dvd player
iam vinverth dvd remoot lost i have unevers remoot setting cod no plz cod no sar
Jan 31, 2010 | Yamaha RAV-202 Remote Control
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Program a remote control
you can only use the original remote control that goes with that Go Video unit. because its a DVD/VCR combo remote there are no universals that will program to work it.
Dec 29, 2008 | GoVideo Televison & Video
Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Apr 07, 2007 | Zenith XBV443 DVD Player/VCR
Sanyo HT32744 32" TV Logo
52 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
