Question about Dryers
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter after removing the back from the dryer. I think the problem is the timer switch but I am not sure how to confirm my suspicion. After energizing the dryer I pushed the start button while turning the timer dial clockwise to different settings. The dryer started up for a short period while the dial was at the end of the permanent press cycle. The dryer did not continue to run as I turned the timer dial into other timer settings. I could hear the timer clicking as though it was cycling but the dryer never showed any signs of starting back up as I continued to depress the start button and turn the timer dial.
  • 1 more comment
  • Anonymous Apr 22, 2009
    Same problem"I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm met"
  • fisherman080 Apr 22, 2009
    THANKS, Anyway! Figured out the Problem. One of the switches located in the timer was bad.
    Disconnect the energy source. I checked all the switches to make sure they opened and closed with an ohm meter. After checking all of my switches & visible thermostats I used the schematic to check the circuits in the timer. We placed a lead on the white and tan wire and as I turned the timer dial we noticed a change in the reading on the ohm meter. The switch that engages when the dryer goes into the wrinkle shield mode was malfunctioning. We placed a jumper from the tan wire to the white and energized the dryer. It worked in all cycles on the timer dial. We confirmed our find by removing the timer and exposing the internal switches in the dial. The copper switch was corroded preventing the circuit to close and the dryer to start up. Although the switch is around $100.00, it will be an easy repair. I would suggest taking a picture or making a diagram of the different color wires and where they attach to the new timer before pulling them off the old timer. A Prayer and an in-law that can read electrical drawings helps. Have a GREAT Day!
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Posted on Apr 22, 2009
417.84052500 electric dry 05 model safe mode code. Everything lights up but won't run
Rocky, Could be door switch problem.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bypass dryer door switch Whirlpool
Dryer Not Starting How to Test the Door Switch
. Whirlpool Kenmore Dryer Repair 01 Won Start or Run Door Switch 3406107...
http://www.selfhelpforums.com/archive/index.php/t-10060.html
Mar 13, 2016 | Kenmore Dryers
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Jun 21, 2014 | Kenmore 659 Electric Dryer
My Whirlpool Dryer GEW9868KQS has power, but won't start when the button is depressed. The sensing light comes on, but the dryer doesn't start. Any ideas?
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Oct 18, 2011 | Whirlpool LER4634J Electric Dryer
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Whirlpool dryer model number WED5300SQ0 wont start
take a meter and check door switch then if good take the back off and check all thermostats,thermal fuse,AND if your belt is off theres a safety switch on the idler pully.hope this helps
Nov 15, 2009 | Whirlpool WED5300S Electric Dryer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
Dryers Logo
364 people viewed this question
Top Dryers Experts
