Question about Plumbing
Repair leaky handle
I have a blanco single handle 157-013 bronze kitchen faucet and it leaks water out of the top of the handle. It does not drip from the faucet but it leaks out of the handle that turns the faucet on and off. It is also difficult to turn the spout from side to side. The faucet is about five years old and I have three of them with the same problem. I am not sure how to take it apart. Is there a tech manual or diagram that shows how tom take the faucet apart and repair the leaks and losen the spout?
  • Anonymous Apr 23, 2009
    Blanco Classic faucet - 4-5 years old - leaks form the base, on top of the counter. Is this a cartridge problem?
    Sergeant:
    Champion:
  • 260 Answers
Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
Posted on Apr 23, 2009
How do i remove the stem from an Elkay kitchen faucet model # LK7124?
Leaky Elkay single handle kitchen faucet - DoItYourself.com ...
www.doityourself.com/.../292646-leaky-elkay-single-handle-kitchen-fau...
Can I replace the cartridge (A54236R) from our single handle Elkay (LK-6360) kitchen faucet without removing it from the sink top? If so where is the secret inhex ...
Jan 14, 2016 | Elkay Plumbing
Leaky kitchen faucet
What kind of faucet? (single handle, double hndle, kitchen, bathroom) Where is it dripping from? (handle, aerator or faucet head, under the sink) There are many types of faucets and many types of leaks. Sorry to be so vague but there's a pretty wide spectrum of possibilities, a little more info will go long way.
Feb 04, 2013 | Plumbing
K-12177 leaking around top
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 24, 2013 | Kohler K-12177-G Fairfax single-control...
I have a blanco kitchen faucet that is about 5 years old. it seems to be leaking from inside the unit itself , problem is , trying to figure out how to get it apart to repair it.
behind the handle there should be an allen screw under a crome cap . once you reove the screw the upper metal ring should just unscrew then there are a series of o rings that can be replaced
good luck James
Dec 26, 2010 | Blanco Classic Single Handle Faucet with...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
Water leaking from the faucet onto the countertop.
http://docs.homeclick.com/PE-Links/Rohl/Rohl-A3608-specs.pdf
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
Jun 04, 2010 | Rohl A3608LMPN Single Lever Country...
Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
May 30, 2009 | Blanco Classic Single Handle Faucet with...
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Feb 12, 2009 | Blanco Classic Single Handle Faucet with...
Plumbing Logo
534 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
