Question about Kenwood Car Audio & Video
Need wiring diagram for kenwood car stereo red positive black neg yellow ground?
    Genius:
  • 1,039 Answers
Red wire connects to Acc, yellow wire to constant +12volts , black to car body, ground. Do not connect the yellow thru the igniton switch (Acc). This will burn out your ignition switch.Connect diectly to Batt thru a fuse.
Posted on Apr 25, 2009
I need awireing diagram for a premiun sound (jbl) stereo with cd player for a 93 thunderbird
you should get a wiring harness to save you the trouble, however i just put in a kenwood in a 1997 thunderbird, if you cut the black wiring cover all the speaker wires are wrapped together and the other wires will be 12v constant acc, ground, etc. here is a diagram Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire : Orange/Green
Left Front Speaker Negative Wire : Black/White
Right Front Speaker Positive Wire : White/Green
Right Front Speaker Negative Wire : Black/White
Car Audio Rear Speakers Size: 5x 7 speakers
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire : Pink/Green
Left Rear Speaker Negative Wire : Pink/Blue
Right Rear Speaker Positive Wire : Pink/Blue
Right Rear Speaker Negative Wire : Green/Orange
Feb 03, 2013 | 1993 Ford Thunderbird
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Illumination Wire: Red
Car Stereo Antenna Trigger: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
May 31, 2011 | Car Audio & Video
Trying to find a wiring diagram to install my kenwood kdc-mp342u into my 2001 grand am. any ideas?
Please let me know if you have any questions, and thanks for using FixYa.
2001 Pontiac Grand Am Car Audio Wiring Diagram kenwood kdc-mp342u
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: none
Run a wire to the fusebox for switched power. red
a 14 gauge wire will do--use a 15 amp fuse
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Gray (tape this wire off) none
Car Stereo Dimmer Wire: Brown (tape this wire off) none
Car Stereo Amp Trigger Wire: Pink blue
Left Front Speaker Positive Wire (+): Tan white
Left Front Speaker Negative Wire (-): Gray white/black
Right Front Speaker Positive Wire (+): Light Green gray
Right Front Speaker Negative Wire (-): Dark Green gray/black
Left Rear Speaker Positive Wire (+): Brown green
Left Rear Speaker Negative Wire (-): Yellow green/black
Right Rear Speaker Positive Wire (+): Dark Blue purple
Right Rear Speaker Negative Wire (-): Light Blue purple/black
Amplifier Mounted behind trim in the left side of the trunk.
May 19, 2011 | Kenwood Car Audio & Video
I have no harness labeling ground, hot or speaker wires, I need diagram
Alot of new stereos have an ISO color code,
This is mine:
Car Radio Constant 12v+ Wire: White/Green
Car Radio Switched 12v+ Wire: White/Red
Car Radio Illumination Wire: Red/Black
Car Stereo Antenna Trigger: Yellow/White
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Apr 25, 2011 | Jensen Car Audio & Video
I have a 1991 Chrysler new yorker fifth avenue, I'm trying to convert the radio to a Kenwood... I've been searching for a Diagram and none of them have the colors that are on my car...
New Yorker and Fifth Ave have different colors for RR speaker neg. Does either of these match up?
1991 Chrysler New Yorker Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Audio Front Speakers Size: 3 1/2?
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
1991 Chrysler Fifth Avenue Car Radio Wiring Schematic
Right Rear Speaker Negative Wire (-): Brown/Yellow
Oct 03, 2010 | Chrysler Fifth Avenue Cars & Trucks
I need to know wat colours do wat on a kenwood KVT-739 car Stereo DVD player wiring
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Aug 16, 2010 | Kenwood Car Audio & Video
I need diagram of the stereo wires to put in an aftermarket stereo
1996 Honda Accord Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/White
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Stereo Antenna Trigger Wire: Yellow/White
Car Audio Front Speakers Size: 5 1/4′
Car Audio Rear Speakers Size: 6 1/2′
Nov 24, 2009 | 1996 Honda Accord
What wires go together for the constant on a 94 ford ranger
1995 Ford Ranger Pickup Truck Car Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Green/Purple Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: Blue Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 6 1/2′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Orange/Light Green Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Car Audio Rear Speakers Size: 5′ x 7′ Car Audio Rear Speakers Location: Rear Corners Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 14, 2009 | Kenwood Audio Players & Recorders
Wiring diagram for an aftermarket stereo, pioneer cd, am fm, which wire is for ground, which is hot, and the speaker wire colors?
black ground red accessory (KEY) yellow memory constant power,blue is remote,orange is for the dimmer,green with black is left rear neg.and green is positive,violet black is right rear negative and violet is positive,white is left front positive and white with black is negative,gray black is right front negative and gray is positive.
Sep 03, 2009 | Pioneer DEH-1500 CD Player
94' plymouth voyager care stereo wiring diagram needed
1994 Plymouth Voyager Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Ground Wire: Strap or Chassis
Car Radio Illumination Wire: Black/Yellow
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Violet/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Yellow
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jul 05, 2009 | Metra Chrysler/Dodge/Plymouth Speaker...
Car Audio & Video Logo
344 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
