Question about Toshiba Satellite A135-S2276 Notebook
Screen went black while using my toshiba satellite (A135-S2276). I turned it off and now it won't turn on. Green light comes on for a couple seconds and I here a click and it turns off. Pulled battery and checked charger and they seem O.K. Any suggestion.
My own suggestion to this problem is that, when the screen trurned to black like that means that somethng has happened to your screen. Then, you needs to trubleshoot you pc, in what ways? Simple plug your pc with the recommended adapter and start pressing your caps lock to find out whether the blue light will comes up, when the blue light comes up, your pc is ok, then, your have to deal with the screen first check the screen module as well as flex cable at the back of your pc after all these were done, you must definitely get ride to this mura.
Posted on Apr 28, 2009
I turn on the computer the green light is on but the screen is black it want start up at all. It is froze
turn it off, put in your toshiba repair disk and turn it back on, that should fix your problem
Dec 12, 2010 | Toshiba Satellite A135-S2276 Notebook
Screen keeps going black. Will come on after
It sounds like a problem with the backlight, but could be a cabling problem as well, or a voltage problem (least likely).
May 05, 2010 | Toshiba Satellite A135-S2276 Notebook
Power on No Display(Black Screen)
try pressing FN and F6 together when u turn it on
Mar 11, 2010 | Toshiba Satellite A135-S2276 Notebook
My Toshiba Satellite A135-S2276 it turns on but has no display nothing comes up on the screen wat do you think the problem is?
On the main motherboard there is a surface-mount, very small, black fuse(has an "f" printed on it...with power OFF use an ohmmeter from one side to other....should read "zero" if good; if you're good at minute soldering, you can solder another one on top...don't have to remove old one, otherwise you will have to buy a new board,$80, and replace it...be sure to reconnect all the connectors back.
Mar 07, 2010 | Toshiba Satellite A135-S2276 Notebook
Screen went black while using laptop, have rebooted, goes black 1 sec after starting up
i have the same problem with my Satellite A135-S2256, starts up all lights light up except processor light, fan turns on but CD/DVD drive wont turn on : ( any ideas on why? how to fix?
Thank You
Oct 22, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a130/a135 series. I connect to
check the power cord to the laptop in the back wiggle it. check the lights. if they come on and go off with you giggling the power cord. the ac input socket may be broken. you may have to wedge it in one spot to get the two lights to come on let it sit there a while 20 min to charge battery some then turn on laptop.
Jun 23, 2009 | Toshiba Satellite A135-S2276 Notebook
Computer Screen Went completely blank and wont turn on
You might want to plug in external monitor to make sure your screen did not burn out before doing anything else.Good luck and have a good day.
Jan 30, 2009 | Toshiba Satellite A135-S2276 Notebook
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Default bios password toshiba satellite a135-s2276
the best thing is to do the system recovery process ..
Aug 09, 2008 | Toshiba Satellite A135-S2276 Notebook
Laptop
it turns on for a second while raising the lid and then goes right back out leading me to believe its the lid switch or senser. But i am unable to locate it. My machine is a toshiba satellite A135-S2276. Please help!
Aug 26, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
224 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
