Question about Sunbeam Vacuums
Changed the motor carbon brushes on my Beam central vacuum cleaner equiped with an IntelliWatch system. This system includes the Alutron DB100 module. This Alutron module needs to be reset so that the vacuum cleaner can operate properly. I believe that this module keeps log of running time and disables operation after a predetermined time. Can you help me with providing a reset procedure that will reset this module. Thanks
SOURCE: fantom upright vaacum- cyclone XT
There are two screws just to the rear of the accessory compartment. There are also two hidden screws under the cord retractor lever. I tried to get the retractor off by pulling upward on it, but it just wouldn't come. It is not screwed down but held by friction via its hinges. The way I got at the last two screws was by drilling a couple of holes thru the plastic cord retractor lever - about 1" from the end of the lever on left side (looking from the rear of vac) and about 0.5" from the other end of lever.
Posted on Dec 06, 2007
reddevil6
  • 1673 Answers
SOURCE: need to download users manual/how to install brush belt
http://bissell.com/images/UserGuides/7901.pdf
same as 8901
Posted on Jan 17, 2008
RockyNR1
  • 324 Answers
SOURCE: Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Posted on Nov 06, 2008
  • 1214 Answers
SOURCE: central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Posted on Jan 23, 2009
  • 694 Answers
SOURCE: how to replace central vacuums Carbon Brushes
The entire brush and holder assembly has to be purchased/replaced. That's the plastic piece that screws on to the motor. I don't think you can even get brushes for their machines anymore.
Remove screws. Remove plastic piece from motor. Replace.
Posted on Oct 17, 2010
Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Apr 08, 2013 | Sanyo Vacuums
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power light on but motor won't run. where do i
the motor carbon brushes need replacing which is a most difficult job to get the cleaner disassembled. Brushes are easy to fit if You have replaced carbon brushes in other appliances etc..
Getting to the brushes in the Kirby is very difficult...
Lee in Australia
Jul 28, 2011 | Kirby Generation 3 Bagged Upright Vacuum
Took my miele canister vacuum cleaner in for repair because the cord had a break in it creating a short. He said it also needed an inter filter ($12.29) and the carbon brushes were worn out ($21.95). Is...
Depending on the age of the vacuum and how much use it gets, the first two are possible. I would question the brushes as they should last for several years.
The servicing is generally for labor only and doesn't include parts. I do recommend this regularly, more often if used a lot (yearly).
Feb 15, 2011 | Miele Vacuums
How to replace central vacuums Carbon Brushes
Oct 17, 2010 | Electrolux Central Vacuum
Motor will not start
You appear to be describing a case of motor brushes worn out. They may be replaced on some motors, but if there is damage to the motor armature (the rotating part the brushes contact) rhe brushes mayu not last long.
Mar 11, 2010 | Beam Industries 2775 Serenity Plus Central...
I have a Beam Central Vacuum cleaner. I can't dislodge a piece of mulch from the rug attachment, and the motor won't turn on.
Don't know which power head you have, but if there is a base plate, take it off, you should be able to get to the debris from there. If not, remove the screws from the bottom and remove the top. Some also have a cover over the brush roll, remove it and then you can get to the brush roll and inlet. It stalled the brush roll, that is why the motor won't turn. Some have a reset on the back of the power head and it most likely tripped, just push it back in.
Aug 05, 2008 | Vacuums
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Motor won't turn on
It sounds like you have a motor problem there. I don't know how old your machine is, but if it is still under warranty, don't explore any further as you will void your warranty. This problem sounds like a carbon brush problem and you will not be able to address it yourself unless you know your way around an electrical motor. The carbon brushes can stick or become jammed and once they are loosened up, they need to be reseated or the motor will burn out. You will not be able to do this yourself. These motors generally have 5 to 12 year warranties and yours may still be under warranty. If your machine is over 10 years old, the carbs are probably worn out and the motor will require repair or replacement. You should refer to a competent tech for help.
Jan 13, 2008 | Beam Industries 2775 Serenity Plus Central...
Vacuums Logo
207 people viewed this question
Top Sunbeam Vacuums Experts
Terry Weaver
Terry Weaver
Laura Muresan
Laura Muresan
Are you a Sunbeam Vacuum Expert? Answer questions, earn points and help others
