Question about Sharp AL 1631 Copier
SHARP AL1631 IT MAKES SOME NOIES THE LETTER L1 COMES ON THEN IT TURNS OFF.
  • 51 Answers
Check the scanner lock knob.
Posted on Apr 21, 2009
Tip
Sharp AL Series Copier L1 L-1 Error Code Cause and Solution
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Does the sharp al1631 have a hard drive
There is NO hard drive in the AL1631. I have worked on hundreds of these and can say with certainty there is no hard drive.
Thank You for using Fixya.
Oct 20, 2010 | Sharp AL 1631 Copier
Sharp Al1631 unit won't copy; just spits out blank papers
check for empty toner... and if the laser lamp is dim or out... the laser lamp is the lamp that comes on when you copy from the glass table or through the document feeder
Dec 09, 2009 | Sharp AL 1631 Copier
A loud clicking sound
This means that a gear is jammed or broken somewhere. Check for waste full and empty or drum waste roller and unblock the jammed toner inside that unit or check fuser gear if broken then replace it.
Nov 23, 2009 | Sharp AL 1631 Copier
Makes thumping noies under cab when goind down the
have the transmission mount checked or the cross member bolts to make sur they are tight
Nov 19, 2009 | 2003 Ford F250 Super Duty Crew Cab
ROLLER ROTATING KNOB TURNS CONSTANTLY ON SHARP AL1631
Many copiers will do this if you have run out of toner.Copiers will turn over trying to add toner from the cartridge to the developer unit.
Nov 18, 2009 | Sharp AL 1631 Copier
Al1631 sharp copier
This is called error code which you must specify.For H2,H3,H4, use command 14, for U2 use comm 16.Please specify if neither of this displays.
Oct 02, 2009 | Sharp AL 1631 Copier
Turn the copier on then the number 1 comes on then the letter l comes on then the copier turns off
If this is a Sharp copier then L1-?? refers to the scanner section of the copier. If this is a little desktop model then moth likely the scanner lock is engaged (found under the left side of the scanner glass).
Apr 21, 2009 | Sharp Office Equipment & Supplies
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Sharp AL 1631 Copier Logo
103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
