Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
New rth2310 themostat does not blow cool air
My husband installed this new thermostat and only heated air comes out even when it is set to cool.
  • tikitank89 Apr 22, 2009
    No. The new one only uses 4. (R,G,Y,W) The old one (LUXPRO)has 7. (r,G,Y,W,O,E,B) I put the old one back one and it works perfectly. Can't figure out which wires to use on the new Honeywell.
  • Samuel Charles Spriggs May 11, 2010
    Sounds like it's just wired incorrectly or it's the wrong thermostat. Is the new thermostat designed for the same number of wires as the old one?
    President:
  • 1,489 Answers
I don't believe you're going to get the new one to work -- sounds like it doesn't have enough control wires to operate your HVAC system. If it is designed to operate a 7-wire system, the documentation should show how to hook the 4-wire tstat so it will work.
Posted on Apr 22, 2009
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Unit blows cool air while in heat mode
model number? Heat pumps tend to blow cooler air than a space heater unless in money-gobbling mode.
Mar 28, 2014 | LG Heating & Cooling
Airhandler- the themostat is on auto/I understand cool,heat.emerg heat,The (G) terminal-then why heat mode or,emer heat fan blows?Only when i switch to cool mode the handler still want start up blowing...
the fan fill come on with the sequencer (stack switch you call it) it will also come on with the fan relay. on some goodmans the fan relay is the black box on the circuit board. use a jumper to jump red to green, this should bring the fan on sounds like you could have a broken green wire, try using a different wire instead of green
Sep 12, 2013 | Goodman Heating & Cooling
I just installed a thermostat in my 2000 lincoln ls and now the heater and defrost dont work. heater just blows out cool air
make sure you installed the themostat the right way and that it has the proper heat range for your vechicule.normally after installing a thermostat,you remve the rad cap and fill the radiator with antifreeze,then srart the car and wait till the themostat opens and prestone level falls.refill rad and put rad cap back on.turn on heater and you should have heat,if not have your rad cap tested to make sure it is holding the proper pressure.your antifreeze mixture should be 50\50.
Nov 04, 2012 | Cars & Trucks
Honeywell RTH2310 heating while it's supposed to be cooling
ok to start with if you have a heat pump and not ac over electric heat depending on type but most will be wired as
red to r jumped to rc y to yellow this turns on compressor g to green this turns on fan w to white or brown for electric heat strip or em heat o to orange reversing valve energised in cooling switches from heat to cool or orange to b energised in heating c blue for common
you will have to look at your indoor unit and out door unit to verify what collors the contractor used when they wired it up hope this helps
May 31, 2009 | Honeywell Programmable Thermostat Heater
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Forced Hot Air Heating system doesn't maintain thermostat setting
It sounds like you may have issues with the furnace. A qualified professional can go over the system and the house to let you know if the system and unit are properly sized. The poor performance of a furnace can be a sign of carbon buildup in the furnace.
Good luck, hope this helps.
Matt
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
613 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
