Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Can't get new filter into refrigerator properly
The new filter, same model as required, fits into filter slot but can't turn to lock it in place
  • 490 Answers
They are hard to install push it in all the way and twist
Posted on Apr 21, 2009
Replacing Fuel Filter on 2007 FLHTC Harley Davidson
The fuel pump pressurizes the fuel rail/line to a high pressure in the neighborhood of approximately 58 psi. so to avoid an uncontrolled discharge or spray of gasoline, the pressure must always be bled off prior to fuel line removal and top plate removal. To do this remove the left side saddlebag and the left side cover and then remove the remove 15 amp fuel pump fuse. And then start the engine and allow the motorcycle to run until it stalls and then turn the engine over for about three seconds to remove any remaining fuel from the fuel supply line. THEN remove the maxi-fuse and reinstall the 15 amp fuel pump fuse. THEN remove the filler cap and drain fuel tank with a safe method of your choice and store the fuel or appropriately dispose of it. THEN remove the seat, the console by releasing the socket screw to release front of console from the fuel tank weldment and the hex screw to release rear console bracket from the clip nut on the rear fuel tank bracket. THEN lay a clean towel or towels on the forward part of the rear fender and lay the consoleupside down on them. Then you will need to get a special tool for Cam ring removal and installation. HD have one as part number HD-48646) which tool you will place over the top plate, aligning the four notches at the bottom of the tool with the four tabs on the cam ring. THEN get a 1/2 inch drive ratchet, install it in the tool and rotate in a counterclockwise direction until the cam ring is loose. BE CAREFUL to properly align the tool and push down on it while rotating it to loosen the ring and to control the ring because if it slips off the ting during rotation and hold both the ratchet and tool carefully so it cannot slip and slide across the fuel tank doing substantial paint damage. WHEN it is loose remove the retaining ring, insert a small plain screwdriver between the latch and top plate, depress either side of the latch, gently tug on the harness and remove the top plate by lifting it up. After you have removed the fuel tank top plate and found the ground wire spade terminal in the slot of the fuel filter shell insert the tip of a small flat blade screwdriver through the window to depress a tang, and then pull the terminal from the slot and then gently raise the locking arm and pull the U-clip from the holes in the fuel filter shell and remove the fuel filter shell from the end cap and then also remove the o-ring and filter from the fuel filter shell.
(To reinstall a new filter in the fuel filter shell seat a new o-ring on the counterbore at the top of the filter and then install the fuel filter shell over the end cap, so that the slot in the fuel filter shell engages the index pin on the end cap and then. Holding the parts together, slide the U-clip through the holes on the locking arm side of the fuel filter shell and push the U-clip until its endsexit the holes on the opposite side and then retract U-clip until contact is made with the step in the locking arm. When that is done route the ground wire from top plate TORX screw around the index pin side of the end cap and install the spade terminal into the slot in the fuel filter shell and gently tug on the ground wire to verify that the terminal is locked in place. If the ground terminal does not lock in place properly use a thin flat bladed tool to bend the tang outward slightly away from the terminal body. Then reinstall the top plate.)
THEN locate the ground wire spade terminal in the slot of the top plate, insert the tip of a small flat blade screwdriver through the window to depress the tang, and then pull the terminal from the slot. THEN depress the collars and remove the tubes from the fittings on the fuel filter shell. Move the top plate to a bench area and remove the filter (which would also be necessary it the top plate replacement is necessary and if top plate replacement is necessary, remove the fuel filter shell.
If installing a new top plate, first install the fuel filter shell. THEN inspect the seal ring at the bottom of the top plate for cuts, tears or signs of deterioration and if and as necessary, install a new seal ring with the nubs properly contacting the ring groove walls. THEN move the top plate to the motorcycle and connect the tubes to the fittings on the fuel filter shell noting that the fittings are of different sizes to prevent improper assembly such that the tube with the smaller diameter fitting runs from the fuel pump to the fuel filter housing, while the tube with the larger diameter fitting runs from the fuel pressure regulator housing to the fuel supply valve. THEN install the connector at the bottom of the top plate, route the ground wire from the top plate connector along the inboard side of the vapor valve and install the spade terminal into its slot in the top plate and lightly tug on the wire to verify that the terminal is locked in place and if it does not lock in place use a thin flat bladed tool to bend the tang outward slightly away from the terminal body so that it will lock in place. THEN install the fuel tank top plate engaging the index tab on the outer diameter in the slot at the front of the fuel tank collar, install the cam ring over the fuel tank top plate with the TOP stamp facing UP.THEN if so equipped remove the filler cap from the top plate on fairing equipped models and get an appropriate CAM RING REMOVER/INSTALLER tool and put it in place over the top plate while aligning the four notches at the bottom with the four index tabs on the cam ring and then while all the time pushing down on the tool with both hands rotate it in a clockwise direction until all four of the index tabs begins to engage with the slots in the fuel tank collar at which time insert a 1/2 inch drive ratchet into the tool and rotate the tool until the cam ring is fully installed. THEN re-install the console next by:
FLHR/C: Use caution to avoid pinching the wire harness and the vent tube. FLHX, FLHT/C/U, FLTR: Use caution to avoid pinching the wire harness, the vent tube and the overflow tube and then re-install the fuel filler cap. THEN start to thread in the socket screw to fasten the front of the console to the fuel tank weldment, start the hex screw to fasten the rear console bracket to the clip nut on the rear fuel tank bracket and alternately tighten the socket/hex screws to 36-60 inlbs (4.1-6.8 Nm). THEN re-install the seat, re-install the maxi-fuse re-install the left side cover, re-install the left side saddlebag, refill the fuel tank check to be sure there are no fuel leaks, start the engine and again inspect for any fuel leaks.
Oct 09, 2014 | 2007 Harley Davidson FLHTC Electra Glide...
Tip
How to Change the Filter on an LG Refrigerator
The procedure is as follows:--
1) The water filter located in the top left corner of the refrigerator in the small tube with a bottom hole.
2) Before removing the water, drain the water in the chamber by turning the filter handle counterclockwise.
3) Then carefully slide the cartridge out of the tubing.
4) Take the new filter and push the replacement filter into the filter holder.
5) While placing the new filter the filter handle should be positioned vertically.
6) After placing the filter turn it clockwise to make the new filter fit properly.
7)Test by running water in to the tubing and check if its going freely or getting blocked.
This will help.good luck.
on Mar 15, 2010 | Refrigerators
Water filter on kitchenaid superba not snapping into place
The entire filter with cap attachment must be in place or the water will not be filtered.
Feb 27, 2014 | KitchenAid Superba Architect KSCS25INSS...
My Kitchenaid French door fridge's water filter
If I remember correctly it requires a quarter to half turn to disconnect in the counter clock wise direction. May take some grunt to free it. If that fail try channel lock pliers and be careful to not break it. once turned it should pull straight out. Try that as maybe its not twisted into place properly to start and just needs to be pulled straight out.
Oct 13, 2013 | KitchenAid KFCO22EVBL - French Door Bottom...
How do I replace the 2003 road king fuel level sender
Use the following as a template fro how to get at the fuel sender:
The fuel pump pressurizes the fuel rail/line to a high pressure in the neighborhood of approximately 58 psi. so to avoid an uncontrolled discharge or spray of gasoline, the pressure must always be bled off prior to fuel line removal and top plate removal. To do this remove the left side saddlebag and the left side cover and then remove the remove 15 amp fuel pump fuse. And then start the engine and allow the motorcycle to run until it stalls and then turn the engine over for about three seconds to remove any remaining fuel from the fuel supply line. THEN remove the maxi-fuse and reinstall the 15 amp fuel pump fuse. THEN remove the filler cap and drain fuel tank with a safe method of your choice and store the fuel or appropriately dispose of it. THEN remove the seat the console by releasing the socket screw to release front of console from the fuel tank weldment, the hex screw to release rear console bracket from the clip nut on the rear fuel tank bracket. NOW lay a clean shop towel or towels on the forward part of the rear fender and lay the console upside down on them. Then you will need to get a special tool for Cam ring removal and installation. HD have one as part number HD-48646) which tool you will place over the top plate, aligning the four notches at the bottom of the tool with the four tabs on the cam ring. THEN get a 1/2 inch drive ratchet, install it in the tool and rotate in a counterclockwise direction until the cam ring is loose. BE CAREFUL to properly align the tool and push down on it while rotating it to loosen the ring and to control the ring because if it slips off the ting during rotation and hold both the ratchet and tool carefully so it cannot slip and slide across the fuel tank doing substantial paint damage. WHEN it is loose remove the retaining ring, insert a small plain screwdriver between the latch and top plate, depress either side of the latch, gently tug on the harness and remove the top plate up by lifting it up. THEN locate the ground wire spade terminal in the slot of the top plate, insert the tip of a small flat blade screwdriver through the window to depress the tang, and then pull the terminal from the slot. THEN depress the collars and remove the tubes from the fittings on the fuel filter shell. Move the top plate to a bench area and remove the filter (which would also be necessary it the top plate replacement is necessary).
If installing a new top plate, first install the fuel filter shell pursuant to the fuel filter replacement instructions I have set out below.
Carefully inspect the seal ring at the bottom of the top plate for cuts, tears or other signs of deterioration and if necessary, install a new seal ring with the nubs contacting the ring groove walls. THEN move the top plate back to the motorcycle and connect the two different sized tubes to the proper sized fittings on the fuel filter shell. The tube with the smaller diameter fitting runs from the fuel pump to the fuel filter housing and the tube with the larger diameter fitting runs from the fuel pressure regulator housing to the fuel supply valve. THEN install the connector at the bottom of the top plate and route the ground wire from top plate connector along the inboard side of the vapor valve and install the spade terminal into the slot in the top plate and gently tug on the wire to verify that the terminal is locked in place and if it is not locked in properly bend the tang upward slightly away from the terminal body with a thin flat blade, like that on a hobby knife, to enable it to lock in place. THEN install the fuel tank top plate by inserting the index tab on the outer diameter in the slot at the front of the fuel tank collar and install the cam ring over the fuel tank top plate with the "TOP" stamp facing up. If there is a filler cap present on fairing equipped models, remove it. NOW get the CAM RING REMOVER/INSTALLER tool and one half inch ratchet assembly and place it/them in over top plate carefully aligning the four notches at the bottom with the four index tabs on the cam ring and then carefully pushing down on the tool with both hands, rotate it in a clockwise direction until each of the four index tabs begin to engage slots in fuel tank collar. And continue rotation until the index tabs are all the way seated into the slots. You should use the same care when aligning and pushing down onto both the ratchet and the tool and rotating the tool as was done when removing the ring to avoid unnecessary damage to the fuel tank paint etc. When this done reinstall the console. Being careful to avoid pinching any of the wire harness and vent tube while reinstalling the console back onto the fuel tank and then start the socket screw to fasten the front of the console to the fuel tank weldment and then start the hex screw to fasten the rear console bracket to the clip nut on the rear of the fuel tank bracket and alternately tighten the socket/hex screws to 36-60 in lbs (4.1-6.8 Nm). THEN install the seat, maxi-fuse, left side cover and left side saddlebag. THEN put fuel in the fuel tank, carefully inspect for leaks, start the engine inspect for leaks again.
Fuel Filter replacement instructions:
After you have removed the fuel tank top plate and find the ground wire spade terminal in the slot of the fuel filter shell. Then insert the tip of a small flat blade screwdriver through the window to depress a tang, and then pull the terminal from the slot and then gently raise the locking arm and pull the U-clip from the holes in the fuel filter shell and remove the fuel filter shell from the end cap and then also remove the o-ring and filter from the fuel filter shell. To reinstall a new filter in the fuel filter shell seat a new o-ring on the counterbore at the top of the filter and then install the fuel filter shell over the end cap, so that the slot in the fuel filter shell engages the index pin on the end cap and then. Holding the parts together, slide the U-clip through the holes on the locking arm side of the fuel filter shell and push the U-clip until its ends exit the holes on the opposite side and then retract U-clip until contact is made with the step in the locking arm. When that is done route the ground wire from top plate TORX screw around the index pin side of the end cap and install the spade terminal into the slot in the fuel filter shell and gently tug on the ground wire to verify that the terminal is locked in place. If the ground terminal does not lock in place properly use a thin flat blade,(like that on a hobby knife), to bend the tang outward slightly away from the terminal body. Then reinstall the top plate.
DIAGNOSE as follows:
Feb 24, 2012 | 2003 Harley Davidson FLHR Road king
Old filter in and water started to sputter, made clunky noises and flow very slow. Removed filter and used plug - water ran fine not filtered.- Replaced with new Maytag filter and water sputtered, flow...
Hello there, when new filters are fitted usually they are expected to spurt for a little bit before they normalize and begin to flow properly. Dispense water continuously for 10 minutes. This usually arises when the flow of water through the unit not being allowed through properly and usually takes the new filter a couple of minutes to get accustomed to the water flow and get water circulating through all its components hence the spurts. Alternatively you can check to ensure that the water supply is turned on full and the filter is properly fitted. If all of these are in place then the dispense mechanism might be faulty.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 23, 2011 | Maytag MSD2756G Side by Side Refrigerator
How do I replace the filter in my whirlpool refrigerator, model GR2FHTXT
In the toe grill of your reefrigerator you should find a filter cap that is covering your filter. Rotate this cap to the left 1/4 of a turn you should feel the filter release from the housing then pull the filter out and discard it. Take the Filter cap from the old filter and reinstall on your new filter. Install your new filter in to the housing applying slight pressure turn the filter 1/4 of a turn to the right. You should feel the filter lock in to place. Now with a BIG container go to your water dispenser and dispense about 3 gallons of water.
Sep 01, 2011 | Whirlpool GD5DHAXVY Stainless Steel Side...
I bought a new water filter for our kenmore elite refri. and i cant the filter to stay in, it keeps popping out.
Check the oring seal for damage. If it is not in place - the filter will not fit properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2010 | Kenmore Elite 44723SS Commercial...
Removal of water filter; Whirlpool Gold Side by side model GC3NHAXVY01
Turn the filter CCW and pull out. (water can stay on) remove knob from filter and put it on the new one. Insert the filter and turn CW to lock in place.
Eric
Oct 15, 2009 | Whirlpool Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
75 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
