Question about Pioneer CDJ-800 Turntable
Top plate i would like to replace my top plate of my 800
  • 515 Answers
Re: top plate
What do you mean by the top plate? Do you mean the actual outer shell of the unit itself, or do you mean the platter? Both are available as special order from - and range in price from $40-120
Posted on Sep 23, 2007
0 characters
3 Points
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Turntables
    How to replace ecc83
    Hi Emnas,
    Here is a link and forum that discovers the differences between long and short tube structure. I believe if you join in and signup, there are many skilled minds based on the readings I have experienced within it.
    ECC83 Long Plate vs Short Plate diyAudio
    A place to buy matched sets next. For originality.
    Philips 12AX7 ECC83 Vintage Tube
    Here is one application. Look at the rack towards your left a top the speaker,
    Palmer Eins Part 2
    Here is a roundup and look .Preamp Tubes Review
    And finally your answer by hand built in St Louis Missouri. Do not lose this link. Tube Care Maintenance
    Please take the time to absorb all of the information as the person who researched happily for you . Fare. Well.
    Jul 01, 2014 | Philips Turntables
    We just got a crosley radio CR66 model,we cannot get the turntable to activate,it wont turn!It is brand new! so I dont understand whats wrong? we hear a click sound but nothing happens please help ty Bill
    remove the rubber plate at the top of the record player,, under that is a metal plate, in that plate is a large "sight hole" look in that as you turn the plate around,, look for the belt that has fallen off the motor shaft and the plate itself,, if you can't locate it, there is a spring clip at the base of the post that holds the metal plate on, remove that , you will see the motor shaft, and the ridge on the underside of the metal plate that the belt has to be on, they sometimes fall off in shipping,
    Sep 07, 2011 | Crosley CR248 Turntable
    I need new or used jogwhel for cdj 800 mk2
    For General Service & Support call 1-800-421-1404
    or contact us by e-mail
    For Replacement Parts
    call 1-800-228-7221
    or visit Pioneer Parts Online
    Jun 23, 2010 | Pioneer CDJ-800MK2 Turntable
    Pioneer CDJ-800 screens went bank/dead, still played discs. Now it does neither.
    when removeing top cover you will see the power supply on top right side faceing you.there are fuses on that board. Some of the fuses will look like transistors, however will only have two legs,check all. chances are you may have one or more bad.
    Apr 16, 2010 | Pioneer CDJ-800MK2 Turntable
    My play pause cue button has worn out on my cdj 800 1
    No, the cue buttons for the CDJ800 and CDJ800MK2 are configured differently, and will not fit. You can take your existing buttons off, take them to a body shop, and have them dip it in chrome!
    Hope this helps some.
    - OPTiC
    Pioneer DJ Repair Videos
    Pioneer DJ Repair
    Pioneer DJ Parts
    DJ Parts
    DJ Equipment Sales
    Audio Video Accessories
    Mar 23, 2009 | Pioneer CDJ-800 Turntable
    Replacing cdj cue buttons
    Not hard at all. Just have to open her up. I would suggest purchasing the service manual, which has instructions on doing this and useful for other repairs, as well as parts list, and parts diagrams.
    Pioneer CDJ800MK2 Service Manual
    - OPTiC
    Pioneer DJ Repair
    Pioneer DJ Parts
    DJ Parts
    DJ Equipment Sales
    Jan 22, 2009 | Pioneer CDJ-800 Turntable
    Plugged cdj-800 and mixer into a European outlet-now they won't turn on
    ok, remove screw under the cd mixer and slide down carefully the top of the cdj and then trace where the power cord connects in to circuit(there is a fuse there try to change anew one..thats is!
    Aug 11, 2008 | Pioneer CDJ-800 Turntable
    I can't see the digital readout
    There may have a been a slight power surge which fried either a resistor or IC inside the unit. This is NOT a self repair, and you will have to get it serviced by a professional service center.
    Good Luck.
    Feb 27, 2008 | Pioneer CDJ-800 Turntable
    Pioneer CDJ-800 Turntable Logo
    55 people viewed this question
    Top Pioneer Turntables Experts
    Dennis McCollum
    Are you a Pioneer Turntable Expert? Answer questions, earn points and help others
