Question about Dell Dimension 2400 PC Desktop
Hard Disk failure
Hi everyone. thanks for taking the trouble to read this. I have a dell desktop and my secondary hard disk is failing. i have partitioned the hard disk into two but i already have a primary disk. the primary disk seems to work fine. but the secondary disk asks me to format it anytime i try to access any of the two partitions. i cant afford to format it because i have a lot of important data on it. thanks again for reading and i hope you can give me some help here. thanks.
  • 4 more comments
  • maftiblaze Apr 27, 2009
    Hi everyone, sorry i didn't write back early, and thanx for your replys. Mircenaj, what you are saying is right. Previously, secondary disks partitions were named "Stuffs" and "Magazine". But after it started failing, they have all been named local disks. But can i run chkdsk from startup before windows boots? How do i do that? Diskcanfixit, I dont have that much to spend on recovery, so pls give me more advice. Anyway, im gonna run the checkdis. an one more thing, it keeps very long-about 10 mins-to boot. Meanwhile it doesnt boot from the failing disk. Please Help!!!!
  • maftiblaze Apr 29, 2009
    I run chkdsk, it only recovered one partition. but the other where the most important stuffs are, it says it couldn't read some of the sectors. What do you suggest? Thanks.!
  • maftiblaze May 02, 2009
    Mircenaj, i downloaded the acronis disk director but i dont know what to do now. How do i use it. When i open the software, it sees all the hard disks including the partition that i can't access. It sees the name and the capacity. How much has been used and what is left. But there are bad sectors on it. I want to at least copy the files on it onto the other partition. Please help. thanks.
  • maftiblaze May 03, 2009
    hey can anybody give me a clue. I need some help here. I gotta get these pictures from the hard drive. they are very important to me. or can anyone give me any software that i can use to retrieve ma files back? I need your help urgently. thanks. i installed acronis disk director and it saw the disk, the capacity, the free space as well as the used space. But it couldn't access the content of the disk. windows sees it alright but when i try to access the files, it says the drive is not formatted so i should format it. I tries scandisk, in dos. it saw a lot of bad sectors it couldnt read, about 15 of them. is it that seriouse? i know that once there are bad sectors i may not be able to access some files but what about the places without the bad sectors. cant i access the files on the sectors that are not bad. a friend says i should put it in a freezer overnight but he didnt tell me how to do it. is it ok to try that? thank you. please help.
  • mircenaj May 11, 2010
    Ok, let me get this straight, you have two discs, one that has your operating system, and a second one with TWO partitions, and whenever you try to access the secondary disk, it asks you to format it?
  • Dick
    Dick May 11, 2010
    The question now becomes "how much do you want to spend recovering the data?" If you can restore your backed up data from the bad drive to a new drive - no problem. If you have no backup data and your data is important you will be learning a lesson painful to your wallet. Call a local computer place and ask what they charge to recover the data on your drive. IF you can put the drive in an external enclosure and it works long enough to copy the data on it to a new drive - you got lucky. Try putting the drive in a Ziploc in the freezer overnight to maximize your chances with this method. There are places that can disassemble your drive and put the plates into a new drive and recover the data that way. The cheapest I've heard of is around $500 for something like that and it could be much more.
  • 61 Answers
Try to run CHKDSK from command prompt, and if that doesnt work, its probably corrupt / hard to recover
Posted on Apr 21, 2009
    Novelist:
  • 177 Answers
Ok, If you want to Keep all the data AND be able to boot into that secondary Hard Disc, Then You Need toBoot into your primary Hard drive, Navigate to the Secondary Hard Drive from within Windows.................
then, back the data you want to save onto: DVD-Rs, CD-Rs, External Hard Disc, Flash Drive, etc..
And Then Delete the partitions and Reformat it.
If That doesn't fix your problems completely, then your Hard Drive has seen better days and needs to be replace. But I'd Try The Above First......at least this way, You won't lose your data!
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
How change prymari device?
You can either look into this online manual or follow the instructions given below.
http://support.dell.com/support/edocs/systems/dim4700/en/om/Y69490LRs.pdf
In the case of loading a particular Operating System(OS) from a specific Hard Disk, you can change the boot priority from BIOS (Hope you know to get into BIOS) as shown in the picture
Or if you want to change the physical configuration of your Hard Disks to Master and Slave, then follow these steps.
  1. Open up the side panel of your PC Case.
  2. Disconnect all the wires from both Hard disks.
  3. Look over the labelled top part of each hard disk to know the settings of JUMPER PIN so as to set it as primary(master) or secondary(slave). Please note that if you are using IDE hard disk, this may be enough. But in the case of SATA, inspite of this, you may also require to install RAID Driver after connecting them back into the computer. These drivers can be downloaded from http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection (You may require to set up your product manually and download Serial ATA drivers)
  4. (Connect them back, Screw up- if you haven't done it already). Now you may be able to use the required hard disks as primary(master) and secondary(slave).
You can also watch two videos of changing jumper of the hard disk. But be careful while replacing jumper. Any incorrect configuration or jumper setting or damage of pin may cause in device failure or result in damage of your hard disks.If you have any further doubts, feel free to ask me...
Jan 07, 2012 | Dell Dimension 4700 PC Desktop
My Dell Dimension 2400 refuses to load Windows XP
What happens?Does it hang on the loading page or does it restart itself before loading?
If it hangs on the loading page,press CTRL,ALT and DEL.This boots the system.
If it restarts itself,remove the hard disk and re-fix it again.Problem solved?
Remove the CMOS battery and the hard disk and re-fix them again.Problem solved?
If not,you may have to repair your operating system.
This how you do it:-
  • Remove your hard disk and enslave[fix it as a secondary drive] it on another machine with a good operating system.
  • Start the machine.Accept to run unnix[using two drives]
  • The machine will automatically detect your hard disk's failure on the operating system and repair the damaged files.
  • On completion and after Windows opens,turn off the machine and remove your hard disk.
  • Fix the hard disk now on your machine and start it.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Dell Dimension 2400 PC Desktop
Diskettedrive 1 seek failure primary hard disk drive 1 not found secondary hardisk drive 1 not found cp says strike f1 but cp boot only up to xp logo then re start again and so on again and again
If both of the hard drives are on the same data cable/disk drive controller it is unlikely that both the have failed. Reseat the data cable connectors on the hard drives and at the motherboard.
Reboot you computer and hopefully it will boot up.
Check the BIOS configuration to see if the BIOS detects the hard drives.
If not the disk drive controller on the motherboard may be faulty.
Aug 26, 2011 | Dell OptiPlex GX150 PC Desktop
Dell inspiron 530s intel 2 windows vista, black screen at startup than disk read error
Disk read error happens when there is a hard drive failure (sometimes in isolated spots and some times crital failure) if you have another computer, you can try connecting the hard drive as secondary and check if you can backup. The solution to this problem is to replace the hard disk drive.
Feb 03, 2011 | Computers & Internet
My Dell Opt, Plex GX 260 reads "Primary hard disk 1 not found, and secondary hard disk 2 not found" ? please help?
You can reseat both cables for both hard drives, however its sounds like the mother board is bad.
Oct 20, 2010 | Dell OptiPlex GX260 PC Desktop
Reads boot disk failure 0
Boot disc 0 failure is usually indicative of the failure of the hard drive that contains the operating system. Make sure the hard drive is well seated into the cables and that the cables are seated onto the motherboard. If it all is well, then the hard drive has most likely failed and needs to be replaced.
May 19, 2010 | Dell Dimension C521 PC Desktop
Primary drive 1 not found
Try to use a different IDE cable. If that doesnt help, change your hard drive cable to the secondary IDE slot on the mainboard and change your BIOS accordingly, If still nothing try running two different drives wether its a hard drive, cd rom on one cable, or 2 hard drives doesnt matter just make sure that your jumpers are set properly.
Jan 09, 2010 | Dell Computers & Internet
Hard disk failure
What exactly does the error say?
The safest thing to do is to stop powering up the hard drive. Get a new hard drive and adapter cable to pull the data off the old hard drive (secondary) and onto the new hard drive (primary) after the new hard drive has been formatted.
If you don't feel you can safely do that, you may want to seek the assistance of someone who can or a company that provides hard drive recovery services.
A hard disk failure error typically indicates the hard drive has (or is about to) fail and become useless.
Jan 03, 2009 | Computers & Internet
Dell Dimension 2400 with secondary SATA hard drive keeps crashing
generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
Jun 20, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
237 people viewed this question
Alun Cox
