CD BURNER/DVD BURNER NOT WORKING
I HAVE ALWAYS BEEN ABLE TO USE MY CD AND DVD BURNER, AND NOW ALL OF A SUDDEN MY SYSTEM IS TELLING ME THAT MY BURNERS NEED TO BE CONNECTED AND TO RESTART MY PLAYER. I HAVE A DELL DIMENSION E310 WINDOWS XP. I HAVE TRIED READING THE TROUBLESHOOT INSTRUCTIONS AND DOING AS TOLD, HOWEVER IT IS NOT WORKING. CAN YOU HELP?
  • 531 Answers
Microsoft Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this imageCD BURNER/DVD BURNER NOT WORKING - vistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this imagesecurityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Now go to the "Did this fix the problem?" section. Back to the top Microsoft Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
Posted on Apr 21, 2009
MY BURNER SUDDENLY REFUSES TO BURN ANYTHING! ANYTHING I TRY TO BURN SAYS DISC COPY FAIL.....CAN YOU HELP ME PLEASE? ANY SUGGESTIONS?
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there probably bad/faulty
hope this helps
Nov 16, 2010 | SySTOR Systems (400S52) Burner
Dvd RW Burner stopped working after only having it for a year
Check whether the CD/DVD drive has been detected/recognised in device manager. Also check the device status in device manager. Try to install the latest drivers for CD/DVD drive will solve your problem.
Dec 15, 2009 | Gateway (1531356) DVD±RW Burner
My LG GSA-H55L super multi DVD rewriter seems to suddenly have a problem recognising disc. I am using the same discs as before (same batch) but now it always tells me no disc.
have you tried a cleaning disk?if not get some cleaning alchol wipe the disk leave a little on it not much,insert the disk ,this might clean the lense.
Sep 11, 2009 | LG 20x8x20 GSA-H55L Super-Multi Disk...
Dvd and cd burner problems
why can't i burn a dvd or cd on my used dvd rewritable drive the destination drive won't show my dvd burner?
Mar 17, 2009 | Philips Phillips 16X External DVD 2XRW...
DVD Burners work most of the time
your system memory is not sufficient for the processes you want to do. Upgrade memory.
Dec 26, 2008 | ASUS (90-N801G1100) CD-RW/DVD-ROM (Combo)...
Dvd reading problem
it may be due to virus..dont try decoders..and just remove the drive and clean ur lens with an soft cloth..no need to remove from the cabint..
if u have an software isobuster then use it,nor download it's an freeware..stil it doesn solve tell me..
if it works den do rate me
ne other queries tell me...
im always der to reply..
cya..
Apr 11, 2008 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
Won't recognize CD Rs
hmm..odd..to say the least..you using another kind of CDR? and did you update your dvd drivers lately?
Mar 09, 2008 | HP dvd740i DVD±RW Dual Layer Burner
Everio cd burner
simple as it sounds...unplug the sharestation for a few seconds. this seems to reset it and it may work for you. when you do this, turn off the camera also, kinda resetting the whole system
Aug 30, 2007 | JVC Everio Share Station DVD Burner Burner
Audio Playback Problems
The drivers packed up update them or reinstall a driver for your dvd cd or k16?
Aug 26, 2007 | Pioneer DVR-K16 Burner
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
