Question about Dual Strata Antenna System - Checkpoint Systems Microphone
Adjust the sensitivity of the sensor on a Checkpoint Strata
How do you adjust the sensitivity of the sensor on a Checkpoint Strata antenna? It barely senses anything at the moment.
How do you adjust the sensitivity?
Download the
TD-20U Sensor Transmitter Installation Manual It explains how to set the Detection Area Pattern.
Setting the correct pattern will avoid false detection.
May 01, 2014 | Optex td-20u, long range in/outdoor...
My garage door will not open, the door gets close to the ground, then back up again. one sensor is green and other one yellow color. Please help me. My email- frooty2cute@yahoo.com
LUBE THE SPRINGS AND ROLLERS WITH WD40.
WATCH THE SENSOR LIGHTS TO SEE IF THEY GO OFF JUST BEFORE THE DOOR CLOSES. IF THIS IS THE PROBLEM EITHER ADJUST THE TRACK OR MOUNT THE SENSORS TO THE WALL INSTEAD.
IF THE SENSORS STAY LIT AND THE DOOR STILL REVERSES AFTER LUBE. ADJUST THE DOWN SENSITIVITY ABOUT 1/8 TURN AT A TIME (LESS SENSITIVE) ID YOU HAVE TO ADJUST THE SENSITIVITY MORE THAN 3/4 YOU WILL NEED TO CALL A PRO OUT TO CHECK THE PROBLEM.
HOPE THIS HELPS
Oct 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Adjusting the sensitivity of my motion sensors
No adjustment on sensor other than masking its view.
AlarmProfessor.net
Jan 28, 2010 | GE Security Simon 3 Wireless Home Security...
How to adjust Dusk Sensing Headlights on a Subaru outback.
Hello, to my knowledge there is no way to do this adjustment manually. You must hook up the Subaru scan tool and adjust the sensitivity that way. If the dealer has already calibrated it once they may have just not desensitized it enough or the sensor is faulty and is not accepting the recalibration protocol and is biased to full sensitivity. In this case the sun-load sensor must be replaced. I hope this info helps...(subytech1)...
Jan 20, 2010 | 2009 Subaru Outback
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
We live in Phoenix Az. We have a 2005 Honda Accord 4dr LX 4 cyl, automatic, AC with factory alarm. The alarm goes off "at will" when parked at home, in parking lots or wherever. It just went off when a...
do you have a remote for alarm? if yes adjust sensitivity with remote push to arm and hold. if you have a sensor under the hood adjust screw on top of sensor.
Jul 22, 2009 | Honda Accord Cars & Trucks
Continuosly alarm going off.
If its an aftermarket alarm check the manual to adjust the sensor sensitivity. If you don't have the manual check the alarm's manufacture website or contact them. Some times the shock sensor is in the antenna itself. There'll be a button saying something like, HI, MID, LOW. Set the sensitivity to MID or medium sensitivity.
May 06, 2009 | 1998 Acura CL
Make car alarm more sensitive
Locate the shock sensor. Using a small screwdriver you can adjust the sensitivity of the sensor. Move srew in only 1/4 turns as this will make big adjustments. Adjustments may make alarm too sensitive so try it out and see what works for you.
Apr 04, 2009 | Vehicle Parts & Accessories
Dual boot Windows XP & Vista Home Prem. x64
It should work just fine, it is actually the best way to dual boot, that way you are not affecting the other OS(s) There is an article about that here : http://www.cas411.com/ShowArticle.aspx?ID=64
Alex
Jul 04, 2008 | Dual Strata Antenna System - Checkpoint...
87 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Lawrence Oravetz
Rishan Ranatunga
Level 1 Expert
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
