Washes but will not drain or spin. I can turn the know to rinse and it still will not drain or spin. could it be only the lid switch and nothing else
  • 532 Answers
Possible,or the belt
Posted on Apr 22, 2009
Maytag washing machine washing but not rinsing, spinning or draining
You need to make sure that the switch on the door/lid is making a connection. If the lid is not closing completely, clear whatever is not letting it close. However, if it's closing but still not working you may need to replace the switch. I have had them go bad and not make a connection when the lid closes.
Mar 31, 2014 | Maytag Washing Machines
My Whirlpool washer won't spin and drain
First test if it is a problem with the lid switch. There are many YouTube videos on how to take apart the control panel and test the pins with a multimeter. On my washer, the lid switch passed the multimeter test but I did my test below and determined it was still the lid switch that was the problem.
When it gets to the point where the washer is supposed to drain and then spin-rinse but doesn't do anything, open the lid and push down on the lid switch lever with a small solid stick (chopstick, screwdriver, etc..) where the lid switch pin would normally push down on until you hear a click. If it suddenly drains, then the lid switch needs to be replaced. If you're lucky, it's a $6 part on ebay and 15 minutes of your time. If nothing happens, then find the YouTube video on testing the lid switch with a multimeter.
Jul 19, 2013 | Washing Machines
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Series 90 Kenmore washes but won't rinse or spin
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Jun 16, 2009 | Washing Machines
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Roper washing machine agitates but will not drain or spin
its your lid switch. it cant spin til that switch is closed,and they break all the time.its thru that hole where the lid seats on the top of the washer.also some times the switch actuator on the lid breaks,but not as offten.inspect that area and you will see issue.you can cut and connect the wires underthere in a pinch[there are three wires to the lid switch.dont connect the green ground its the other two]but you must be careful if you have children they will be curious and lift the lid and it wont stop spinning,so if they reach in with there arm,their has been cases of arms being torn of from spinning tub.how this helps God bless ,tom
Jan 26, 2009 | Washing Machines
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
