Question about Sharp AL 1631 Copier
The #1 comes on then the letter L COMES ON THEN ITTHE COPIER TURNS OFF
    Sniper:
  • 67 Answers
Some one may have latched the scanner which locks the scanner in place used for shipping. If you reach up under the scanner in the cavity where the copies come out there is a plastic piece that turns 90 degrees, if you turn that it may fix it.
Good luck
Bob
Posted on Apr 22, 2009
Printing wavy letters instead of straight
we have similar problem. my printer is canon mp 145. straight lines become wavy and some letters are italics when printed out. it was corrected when i used print head alignment but that was true when printing from my computer and not when using the copier. when using the copier lines still comes out wavy and i cannot correct it until now. please post when you solve your problem. i hope it will help you and i hope you can help me
Jan 21, 2010 | Canon PIXMA MP160 All-In-One InkJet...
When power turned on copier comes on then turns--canon 6012F
check your fixing heater lamp or thermal fuse maybe open or the exposure lamp is defective ,check also for open thermal fuse in series with exposure lamp this a canon generic error if one of the lamps is busted or the AC supply going to the lamps was not detected during power on if the machine detect this situation it will switch off automatically.hope this will help
Jun 27, 2009 | Canon Office Equipment & Supplies
SHARP AL1631
Check the scanner lock knob.
Apr 21, 2009 | Sharp AL 1631 Copier
Turn the copier on then the number 1 comes on then the letter l comes on then the copier turns off
If this is a Sharp copier then L1-?? refers to the scanner section of the copier. If this is a little desktop model then moth likely the scanner lock is engaged (found under the left side of the scanner glass).
Apr 21, 2009 | Sharp Office Equipment & Supplies
Glow plug system does not seem to work
Likely, I would check the glow plug relay.
Mar 24, 2009 | 1996 Ford F350 Crew Cab
Sending print job from pc to IR5000 prints with missing letters
I doubt it's the copier, sounds more like a application or board problem, my first suggestion would be to re-install the driver. the other would be to target the hard drive or memory/ mother board of the network of the copier
Nov 12, 2008 | Canon imageRUNNER 5000 Copier
Car won't always start...turns over and everything lights up.
sounds like a main relay problem it is located left of the steering column under the dash it has i think a gray box it has a red connector i believe it has 4 or 5 wire going to itthe insides can come out without unbolting it from the bracket
Oct 16, 2008 | 1999 Honda Accord
Sharp SF-2014 Copier Jams
1-check and make sure the paper sizes coreresponds : If using Letter it must indicate 8 1/2x 11 or (Letter) not Legal or 8 1/2 x 14.
2- the tires are slipping and trowing the timing off. change tires (cheap)
Aug 20, 2008 | Sharp Office Equipment & Supplies
Faxes coming in sideways
1 solution that i can advice you is that there is a fax setting ( in the fax parameter setting - function 7 - 4) which is about auto reduce all incoming fax to a4 or letter size.
Aug 12, 2008 | Panasonic Workio DP-2500E Copier
Sharp AL 1631 Copier Logo
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
