Kenmore stacked washer and dryer was washer spins but out of balance
  • 77 Answers
Usually there are tension springs or bands that keep the basket pulled evenly in all directions. If one is broke it will cause the load to be unbalanced. You can observe these by unpluging the machine and looking under the drum. Good luck.
Posted on Apr 21, 2009
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Very loud banging and clanking when the drum is spinning
If the dryer is making this noise the roller on the belt tensioner has a flat spot causing this to happen. The roller and belt are replaced as a unit. If it is the washer unit the spring has fallen off on one side of the drum which is one of two that balances the drun while spinning
Apr 28, 2010 | Kenmore 98702 Stacked Washer/Dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 21, 2009 | Kenmore 94802 Front Load Stacked Washer /...
Kenmore laundry center stacked washer/dryer washer tub shakes almost violently on spin cycle.I may have changed setting during spin cycle.Tub is off balance.The appliance cabinet is balanced and on a solid...
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com and enter your full model number for an expanded parts diagram and ordering information.
Apr 11, 2009 | Kenmore Washing Machines
Washer noisy while spinning
You probably have a balance problem. You will have to get a service tech to replace the shock absorber/stabilizers (there are 3) in the unit.
Jan 31, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
