Question about Sony Handycam® DCR-TRV250 Digital-8 Camcorder
Tapes sounding funny
I haven't used my handycam in quite a while and when I went to use it, I removed the old tape (TDK Hi8 MP) and inserted a new tape - (Sony 8mm MP120) and it made a very funny noise, like the teeth weren't matching up correctly. I could have sworn I was told that any 8mm tape would work in this camera, and I thought I was doing it right by purchasing the Sony brand tapes. I bought a 3-pack of tapes and all 3 of them sounded this way. I put the TDK tape back in and it worked. So, I cannot find these TDK tapes anywhere but online. Do I really have to use ONLY the TDK ones?
  • 70 Answers
Try using a smaller tapetime, the grinding noise your hearing is the gears of the tape take up within the casette not the camera, it seems the Sony tapes are 120mins long and the Sony tapes are heavier than TDK and your spool take up on the camera can't take it. the TDK tapes you were previously using may have been a shorter time than 120minute?...try any Hi 8 60min tapes instead. not the 120, they can be too heavy for the take up spool motor of the camera and all its doing is stretching and winding the cassette tape and unable to pull it with a 120 min cassette
Posted on Apr 26, 2017
  • 169 Answers
SOURCE: Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Posted on Aug 11, 2007
  • 107 Answers
SOURCE: Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Posted on Dec 04, 2008
  • 423 Answers
SOURCE: Transfering 8mm video tapes to dvds
Hi there. You need to transfer your videos to your computer and then burn them to DVD using a program like Record Now, or Nero. You should be able to get this from Best Buy, or you can get it online from their websites. If you have any other questions, let me know with a comment. Thanks for coming to FixYa.
Posted on Mar 03, 2009
  • 22 Answers
SOURCE: How do I transfer 8mm & Hi8 tapes to DVD using my computer?
just go to this link:
download the usb driver for your camcorder. install. Set power switch to Camera or VCR. Select USB Stream to ON in the menu settings. then connect camcorder to pc.
Posted on Apr 02, 2009
SOURCE: transfer 8mm,hi8,digital 8 to pc
Since my request..Found i could answer my own questions. Brought firewire card with 6 pin socket.Also brought a cable with a 6 pin to fit the firewire card @ a 4 pin on the other end for the camera .Found my install cd. Loaded the USB installation. Got my connection completed between the camera @ the computer.With regard to the tape formats no problems at all.With nero 6 not sure yet.My home movies go back as far as 1989 and the quality is as good as new.Hope SONY don't stop making the dv tapes. With the external hard drives for editing @ storage need an answer for capacity James from Auckland New Zealand.
Posted on Jun 15, 2009
Hi8 MP tapes
what is your camcoder ? HI8 or Digital 8 did you record all the tapes with same camcoder ?
what ever HI8 doesnt go on Digital 8 and vice versa
Apr 02, 2014 | Sony Video Cameras
No sound on tape playback.
Are you using the sony software to download and convert the video?
Sep 08, 2008 | Sony Handycam CCD-TRV37 Camcorder
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Oct 10, 2009 | Sony Handycam DCR-TRV250E Digital...
TRV87 My older Hi8 tapes have a line always in same place
you may have saved in a different format such as pal.
see if you can select other formats.
of if possible borrow a camera and see if the same thing happens
May 05, 2009 | Sony Handycam CCD-TRV87 Camcorder
Tapes 4 years or older won't play - blue screen/no audio
Answer is No. 2. You probably had light clogged heads and by running couple of tapes, you have cleaned it somewhat. Now complete the cleaning using a new head cleaning tape. Run it for about 10 seconds but not more and you'll be ok. It is recomended to clean head by professional soon. Technician will be cleaning each head manually and you would be sleeping well for a lot longer. -James
Mar 29, 2009 | Sony Handycam DCR-TRV120BT Digital...
Hi8 Tape Will Eject but will not forward/record/rewind,
a problem with an electro mechanical mode-select switch there could be a timing problem arised by mechanical problems on contacts inside (an old video recorder problem between the seventies and nineties ) all equipments where tapes or cassettes are used.
A service manual for timing should be neccesary
Sony CCD TRV16 Hi8 Handycam Camcorder Service Manual Page 13
Apr 01, 2017 | Sony Hi8 Hi-8 Tape
PLEASE DO NOT RETRACT IT BACK manually doing so ,will DAMAGE more the unit ,what you should do is plug the Video Camera AC plug and press the EJECT BUTTON , OR TRY turn in ON & OFF , TO SEE if it works.....
Apr 18, 2008 | Televison & Video
Imovie imports Hi8 tape but not plain 8 tapes
What it is, is the standard 8mm tapes are not digital, and therefore won't import into imovie, unless you have the 8mm to Hi8 option enabled in playback mode, by setting it in the menu, under playback settings.
Dec 29, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Open Questions:
Sony Handycam® DCR-TRV250 Digital-8 Camcorder Logo
53 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
