Question about Sharp Office Equipment & Supplies
Turn the copier on then the number 1 comes on then the letter l comes on then the copier turns off
  • keith640 May 11, 2010
    Which model machine do you have?
  • 63 Answers
If this is a Sharp copier then L1-?? refers to the scanner section of the copier. If this is a little desktop model then moth likely the scanner lock is engaged (found under the left side of the scanner glass).
Posted on Oct 15, 2009
I NEED MY RADIO CODE
Best Answer:you need the anti-theft code to reactivate the stereo. there are a few ways to get it
1) if you have the paperwork that came with the car, there should be a white credit card sized piece of plastic with the owners manual that has the code on it.
2) if you can't find the card, look on the inside walls of the glove box for a white sticker. That sticker should have a 5 digit code. that is your anti-theft code for the radio.
3) if you can't find either, then follow this procedure
with the key in the igintion turned "ON" but the radio turned off, hold in the radio preset station buttons numbered 1 & 6 at the same time. Then, while holding them in, turn the radio ON. You will see a set of 5 numbers and letters come up on the display starting with the letter U. release the station buttons. A second set of numbers and letter will come up starting with the letter L.
write both sets of those numbers down. that is the serial number for the radio. then, call any Honda dealer service department and ask them to look up the code for you. it takes about a minute.
if you bought the car new, call the dealer you bought it from as they may have the code on file without having to go through looking it up
hope that helps
Jun 29, 2015 | 2008 Honda Civic 1.8
Copier won't run. it blinks the letter H and the number 4
H4 Trouble Description
The set temperature is not reached within 90 sec after turning on the power (the heater lamp lights up after 1 sec from turning on the power relay).
After reaching the specified temperature, abnormal temperature is detected.
Cause:
- Heater lamp open
- Defective installation of thermistor
- Thermostat open
Hope helps.
Sep 20, 2011 | Sharp AR-M205 Copier
A letter and number appear alternately
What Letter and What number?. These usually come up as L - 1 or H - 4...both of which are easily resolved. Just let us know what code is flashing.
Feb 03, 2011 | Sharp AL 1631 Copier
WHEN I HIT THE KEYS WITH LETTERS AND NUMBERS ON THEM THE NUMBERS ARE COMING UP HOW DO I GET THAT FUNCTION OFF
Make sure that Number Lock is not turned on. (You can tell if Number Lock is turned on by looking for the LED indicator light shaped like a padlock with a number 1 in it.) If this light is on, press the NumLk key to turn off Number Lock.
That should resolve your problem.
Regards.
Oct 20, 2010 | Panasonic CF30 Notebook
The letter L and then the number 1 appears when we turn on Help
My my how does this work? You will charge me to solve the problem but if I solve it myself you wish me to tell you how. Do I charge you for my solution then ? It makes no sense to me.
I solved it by the way but I'll keep it to myself thanks.
Aug 31, 2009 | Toshiba e-Studio 161 Copier Copier
When I type letters, some of them turn to numbers
Numlock is turned on, press the FN button on lower left and look for the numlock key, you should see numbers 1-9 on the keys that you have been pressing, those buttons have numbers and the letters, just turn the numlock off, and they will be letters again.
Jul 02, 2009 | ASUS Eee 4G Notebook
The #1 comes on then the letter L COMES ON THEN ITTHE COPIER TURNS OFF
Some one may have latched the scanner which locks the scanner in place used for shipping. If you reach up under the scanner in the cavity where the copies come out there is a plastic piece that turns 90 degrees, if you turn that it may fix it.
Good luck
Bob
Apr 21, 2009 | Sharp AL 1631 Copier
I dont know how to program frequiences on the scanner
1. Press Menu (Bottom left hand side of the scanner) You should see "Program System"
Press E You should see "Select System"
2. Turn VFO knob (Top outside right knob on the scanner as it faces you.) until "New System is displayed.
3. Press E
4. Using the VFO knob, select "Conventional then press E three times
5. Press the decimal key until all the letters under "Edit Name’ disappears
6. Now you’re ready to name your system. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
7. Turn VFO to Edit Group then press E
8. Use VFO to select New Group then press E twice
9. Press the decimal key until all the letters under "Edit Name’ disappears
10. Now you’re ready to name your group. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
11. Turn the VFO to Edit Channel then press E. (You should now see "New Channel")
12. Press E then enter a frequency
13. Press E twice
14. Press the decimal key until all the letters under "Edit Name’ disappears
15. Now you’re ready to name your "Subgroup" i.e. " Dispatch" Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E then menu
16. Use VFO to select New Channel
17. Repeat steps 12 through 16
Mar 27, 2009 | Uniden BC246T Handheld Scanner
I press a letter a number comes up as the letter
You have your number lock on. Turn it off and you should be fine.
Jan 28, 2009 | IBM 08K4800 Keyboard for Thinkpad 560Z,...
I need help with my key board. When I use the letter key the number comes up. Such as I push J and get 1 I push K and get 2 . How do I get back to using yhe letter. Thanks Marion
Marion, I imagine this is on your laptop? You need to turn off Number Lock. On Toshiba Laptops, I am pretty sure you hold down the "FN" key and the hit F11. That should turn off your Number Lock. If you look closely at your keyboard, you will see that J corresponds with 1 and K corresponds with 2 and so on.
Hope this helps! Let me know!
May 14, 2008 | Toshiba Computers & Internet
47 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
