Question about GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker quit working.....
I recently encountered that my GE spacemaker quit working last night.  I replaced the fuse and it appeared to work.  I reset the clock.  I tried it again today, and it immediately shut down.  No power.  Can anyone help me.
    Scholar:
  • 126 Answers
Sounds like a short in unit and if it is then must be taken apart to observe operation and failure spot. depending on the age GE has warranties that cover magnatron up to five years< most likely cause of problem> suggest calling company before procieding any further.
Posted on Apr 22, 2009
My ge senor microwave oven model number wes 1450dn1bb quit working
Check the fuse. Bad? Test the door switches and replace the bad one and then the fuse.
Jan 01, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Model XL1400. LAst night quit heating. Everything else appears to be working
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave all of sudden quit working. Had no
Hello :
Maybe there's a problem with the power transformer or the power PCB [ Printed circuit board ] . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service for repairing .
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
good luck .
please rate !
Mar 29, 2010 | GE Spacemaker JVM1540 Microwave Oven
My GE Spacesaver XL1400 quit heating last night. everything seems to be wroking except no heat. Is there something I can check for an easy fix or should I just replace the microwave. thanks, dan
This is a fairly common problem. I have a tip at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat which explains the fix, where to go for parts and how to troubleshoot the unit. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous repair.
Mar 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven just quit. Have checked fuse and plug. Have had no earlier problems. Do these ovens just ''wear out''? It is 8 years old. It is a GE Spacemaker. (November 2002) GE Spacemaker Serial...
yes they wear out. usally the first part to quit is the unit inside that creates the microwaves called the "magnetron" over time they will wear out, and so will the circuitry that runs the entire microwave, some will last 8 years like yours, some only a year or 2. 8 years is pretty good for the life of a microwave. but yea, its time to get yourself a new one. good luck to you
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
GE SpaceMaker JVM140001 just quit
Same thing happened to our unit. My wife had started cooking potatoes and we left house for an hour. Came back and unit was dead, nothing worked. Verified power @ plug. Unplugged, pulled control panel and checked fuse which is mounted @ top of circuit board (will now refer to as CB), back side of interface panel. It passed continuity test. Inspected wiring and was all intact, no sign of burn thru. Varistor visual also looked good, no discoloration or burns. Removed (5) fasteners that hold CB to interface and inspected back side. Noted minor "blackening" @ pin location #1 of the (5) pin plug immediately beneath fuse. Resoldered because connection looked poor. Plugged back in and tested, all features worked correctly!
Mar 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
185 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
