Question about Garden
I cant get my tiller to rev up.
My Statesman tiller won't rev up.
Most problems are due do a fouled carb, because of old fuel most of the time, take the carb off and separate it from the tank and give it a good cleaning and replace with new gaskets and carb parts, use carb clean and air pressure to clean,
Posted on May 14, 2009
Mantis tiller Idles fine, and can even rev... sometimes, but has no power.
check the diaphragm in the carburetor making sure it isn't stiff. depending on how long it has sat, the carburetor may need a cleaning and kit then readjust it to get it to run. Mantis tillers are very temperamental and can be difficult to get to run again even for experienced technicians
Feb 25, 2013 | Mantis 2-Cycle Tiller
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Does MTD make or use to make Statesman rear tillers?
NO THATS MADE BY SEARS HOPE THIS HELPS YA
Dec 08, 2009 | Mtd Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Statesman Tiller
without knowing if its a briggs and straton or tecumseh engine ( I assume Briggs) the carb is where the throttle and gas line connect to. carb will need to be rebuilt most likely and tank will have to be removed to be cleaned. you can email me and I could do it for you I am in wisconsin kerryjonjon at yahoo.com I am the most reasonable in this area. I could do carb and tank if you want.
Jul 11, 2009 | Garden
How do you clean carburetor in statesman tiller? Tiller has been sitting for about a year and there is rust in gas tank as well.
take the carb off and take it apart then clean it with some thing flamable so it burn off with the gas.
Does not reve up engine with trottle cable
The troy bilt tiller is designed so that the engine revs up when the tiller starts to dig. If it is running just start tilling and the engine will rev as it needs to. If it won't start, get back as I can assist you with that.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
240 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
