Question about Gaggia Syncrony Espresso Machine
Gagia Scyncrony Excellent machine, now wont get past the rinsing warming up stage ....any ideas....starting to have withdrawals....
  • 46 Answers
Try a good de scale of the tank and pipe work . remember to rinse / flush well with clean water afterwards. limescale in the smallest form can be a major cause of most faults!
Posted on Feb 09, 2008
SOURCE:
Why doesn't it go past the "pre-rinse" stage?
I would say that there's a very high probability that the heater in the machine has failed. It does the cold pre-rinse but when it gos to the next stage and tries to engage the water heater it detects an open circuit and faults out. You will find replacement heaters on eBay and probably videos on how to replace on YouTube
Sep 15, 2015 | Hoover Washing Machines
MY WASHER IS BLEEPING AND GOT A E;18 ON IT AND WONT FINISH ITS CYCLE
where does it get too??
machine take in washing and lock the door
then add water in stages
and usually heat it as they go
once it comes up to temp
it washes
then it rinses
if it gets to rinse past a water in rotate and wash
then spits the dummy
its most often outlet waste pump or something inside the rubber
between the drum and the pump
if its a front loader and you have kids or dogs
check for rubbish like plastic stuff
inside the drum skin {outer}
ive found in the last week five machine
three had doggy do bags inside the skin melted over the heater
E18 is a timer error with drain
so check out all the drainage
bearing in mind what can get trapped in the pump
brazier wires coins screws nails small plastic bags etc etc
depower the machine at the mains
clean any blockage
then when you power back on
press first the power on or start stop
then mains it should give a long beeeeep and reset...
and not try to carry on the failed cycle
Aug 16, 2014 | Siemens WFXD8400UC Front Load Washer
Top-load Whirlpool washing machine gets stuck on "sensing" stage of wash cycles
Hi my name is Charlie Lapinski. I will help you with your problem
is it locking the door at all?
Mar 29, 2014 | Whirlpool Washing Machines
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Machine will not move past Warming Up start up
check with voltmetar your element on boiler for espresso,element need have continuidi,and check reset button if your machine have button on tank,and check small fuse on tank(with white rubber around)
Aug 24, 2009 | Saeco Royal Digital Plus Coffee...
Washer wont go to rinse cycle or past it
Hi, It sounds like the cold water side is still an issue. Can you rinse with hot/warm water or only cold?
Please let me know so thatI can assist you further.
Thanks
Vic
May 24, 2009 | Washing Machines
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
When the washer go s on rinse the prewash flashes Problem
Mine has been doing the same ... each time it goes to the next part of the cycle the red light flashes but the machine doesn't do anything ... so up till I have been able to get the machine moving to the next stage by pressing the "Start" button ... unfortunately the machine will pause on each stage - meaning I have to press "Start" at each stage!
Dec 15, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Warming up
Machines' heating elements are not heating up. You should have a professional look at it.
Check out www.CeriniCoffee.com
Oct 14, 2007 | Saeco Royal Professional Espresso Machine
Gaggia Syncrony Espresso Machine Logo
100 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
