Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Stuck on SUDS
I have the Kenmore HE3, it is stuck on the SUDS cycle. I let it go but it has now been on overnight and still not cleared. Is there a way to reset the machine, so I can drain it?
  • crohman1 Aug 07, 2008
    I have the same problem. I accidentally put too much HE detergent in the washer, and it stuck on SUDS. (Someone else had put the detergent in, I came in later and added a new amount, so it had twice the recommended amount.) The machine stopped, I took out all the suds, and tried to get it to continue the cycle. The SUDS code remains on, and I can't get the machine to turn off or reset the cycle. Please let me know what ideas you have to fix this.
My wash machine was stuck on suds cycle so I reset it know it is on control lock and will not do anything what do I do ?
Posted on Sep 15, 2008
You must use HE detergent in front loading washing machines.  Regular powders and liquids will cause a sudsing problem
Posted on Oct 30, 2007
My wife runs into the same problem, sometimes she reruns the cycle and sometimes it continues itself. i am presently trying to solve it. she thinks it might be the detergent, she is useing gain powder and liquid.
Posted on Oct 07, 2007
What does 5ud mean on a elite he3
I think the 5UD is SUD. It means excessive sudsing has been detected, and a suds routine has been started to reduce excessive suds. This routine will add time to the original cycle. I have had this on my display a couple of times when I guess I put too much HE soap in the machine.
Jan 15, 2012 | Kenmore Washing Machines
I have a kenmore he3 the erroe code says "sud" can
SUDS LOCK (to much detergent detected during the wash cycle)
he motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Potential Causes
• If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
• Check the drain hose and make sure it is not plugged or kinked.
Dec 16, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
He3 elite kenmore- sUD and F21 error
Hello there"
Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Dec 25, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3 front load washer won't drain or spin and displays sud and flashes FO2
Hi there
I have found this and i hope this gets you in the right direction. Merry X-mas and Happy New Year also.
  • Check Drain Pump
  • Check CCU
Thank you for writing to Fix Ya.
Best regards Richard
Dec 15, 2009 | Washing Machines
My washer goes to suds mode and then flasher f 35
sounds like the wrong soap. are you using H E soap?
Dec 10, 2009 | Washing Machines
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 f02 error
from what i read the presure switch is bad or the presure switch hose is clogged,one guy took the hose off and blew in it and no more f2-mike
Jul 21, 2009 | Kenmore Washing Machines
Kenmore HE3 stuck in rinse cycle
my wife was doing laudry with he3 and when it quite the door would not open.tried to restart a new cycle and it would not start.I unplugged the washer and let sit for 2 min.replugged it in and it started to work.I hope this helps you.
Apr 22, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
108 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
