Question about Brother HL 5250DN Laser Printer
Toner indicator light stays on even though it has been changed. There are no loose parts left in form the toner cartridge used before.
  • 3 Answers
I just had the same problem. We have several of these in our office, but switching toner cartridges made no difference. Then I saw this site: http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
I did steps 14-16, which takes 5-10 minutes. I put the toner back in the printer, turned it on, and it works perfectly now. Give that a try!
Posted on Apr 24, 2009
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Tip
Troubleshooting Toner Leakage Problems
The primary indicator of a toner leak is loose toner particles on the finished document or light prints after replacing the toner cartridge. A few simple steps can be taken to determine the cause of the leak and even repair it temporarily. The simplest explanation is that the cartridge is not properly inserted. Remove and reinsert the cartridge first before proceeding further. The most common cause of a leak is a broken piece of plastic on the cartridge itself. To check for this ailment remove the toner cartridge as you would if replacing it. Spread old newspapers or some rags over a table or counter to prevent a lot of clean up. Gently and slowly rotate the toner cartridge above the rags and look for loose toner falling. It will move similar to light snow falling. It may be tempting to use tape to cover the leak, resist this at all costs. If the leak is miniature use a small bit of clear or black nail polish. It will act like an epoxy resin but is light weight and thin when it dries. Should the hole be a bit large use a small short screw and then glaze it with the nail polish. If the leak cannot be found using the fore mentioned method a seal leak is probably the culprit. A larger leak, such as one located in the seal of the cartridge itself, will need to be replaced. It is much more difficult to find the leak in the seal than a hole in the plastic casing. The seal is under pressure in the laser printer and when removed the leak may not present itself as the seal is at its fullest shape outside of the unit. The only choice left is to replace the cartridge entirely.
on Sep 28, 2010 | Office Equipment & Supplies
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Hp laser 4500 says toner is low or out even after new cartridge
There is a toner sensor in this printer that shoots a beam of light through the toner cartridge. As long as the toner is full and blocks the light, it sees it as being full. If it were the sensor, it would tell you this for all the toners, though. The printer also calculates how much toner may have been used and gives warnings based on that. It could be that this isn't getting reset after you change toner. You can reset the toner gage by going into the reset menu and selecting "New xxxx cartridge" and changing it to YES.
Mar 17, 2009 | HP Color LaserJet 4550n Printer
Toner light stays on
Have you removed the tape?
Try OEM toner from the manufacturer.
Good Luck.
Feb 25, 2009 | Brother HL-2070N Laser Printer
Getting LCD Error: Toner not set Insert Toner
Sometimes what causes the problem is the black cartridge guide on the inside rear of the machine. It comes loose and so when you put your cartridge in it does not line up with the contacts properly. The parts cannot be ordered seperately. It comes with the whole rear assembly. The part # for it is HM1-0244
Feb 14, 2009 | Canon imageCLASS D320 Digital Copier
Error Light
The error is "toner cartridge error" you could try cleaning the contacts inside the printer (with the power off, of course). If that doesn't work you will need to try another cartridge.
Jun 14, 2008 | IBM Infoprint 1116 Laser Printer
CopyCentre C20 Toner Low Stays On
ave you tried shaking the cartridge vigorously from side to side?
The ink may be compacted in one end of the cartridge from storage.
Jun 06, 2008 | Xerox CopyCentre C20 Black and White...
Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
May 19, 2008 | Canon FAX L-120 Plain Paper Laser
BROTHER HL-2040 LASER PRINTER- TONER LED INDICATOR STAYS ON AFTER I REFILLED THE TONER
Dont recomend refills causes too many problems, like you are experencing, put in a real brother toner should fix problem.
great link to explain of lights on panel
Dec 18, 2007 | Brother HL-2040 Laser Printer
Brother HL 5250DN Laser Printer Logo
275 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
