Question about Kenmore Washing Machines
Kenmore washer does not empty on spin cycle & is leaking water
Model #110.29842991
Don't have manual, & don't know how to open it up to get at the pump
  • Kenmore Master
  • 3,361 Answers
This video will show you how to open the cabinet.
Ignore the coupling replacement.
Just use it for cabinet access.
The pump is attached to the motor.
Posted on Apr 21, 2009
Kenmore, model 796.4031, water draining out of opening in back of washer onto floor during spin cycle, this hole is not on the picture in the manual!
Seven water should not be coming out of anything but the drain hose-open it up and look for loose hoes or connection which would leak because of the vibration during the spin cycle-cheers Denny
Oct 18, 2013 | Whirlpool Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
It wont spin or drain. washes fine. checked the lid switch but cant tell if thats the problem or not
This is probably simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the debris trap/filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
You need to locate and clean the debris trap/filter. Depending on the model (not familiar with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 04, 2011 | Kenmore 24032\24036 Top Load Washer
80 series model#26852504. just replaced the trans and now i have to open and close the lid to get the drum to spin
I don't get cold water in the washer. I even changed my water inlet valve. I don't know what else I have to look for. Please post me the solution. The model is Kenmore 80 series-110 26852504
May 17, 2011 | Kenmore 24032\24036 Top Load Washer
January 31, 2010 Kenmore top loading series 80 leaking from bottom toward front. It started during a wash cycle. I put two wet towels back into the empty washer and put on spin, leaking reoccurred. ...
is the pump leaking?or you could have bad tub seals,follow the center trany shaft up to the tub and see if it leaks there,is it noisy when spinning,you gotta just get in there with a light and look around to see where the water is coming from,if you sent pictures they didn't show up,remove the front cover,take out the two screws that hold the console down,remove the two clips with a screw driver and unplug the lid switch wires and pull the cover back and remove it
Jan 31, 2010 | Washing Machines
Kenmore Oasis washer model 110.27032600; trapped hidden water
when you tipped the washer was the drain hose still attached? and if so was the drain hose elevated? most top load washers will have an amount of leftover water in the bottom of the tub. with the drain hose off and the washer tipped towards the rear you should lose any excess water. also try to open the top of the agitator to see if there is any water trapped there. hope this helps....
Oct 18, 2009 | Kenmore Washing Machines
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
126 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
