Question about Rio Carbon MP3 Player
RIO Carbon HOw do I open the case as I need to replace the batery. Thanks
  • 1 more comment
  • bobhawk Jan 05, 2008
    can you repeat the pics and instructions to get at the Rio Carbon battery please?
  • shelfite Feb 01, 2008
    How do you open the case?
  • dynamohum Sep 06, 2008
    How do I open the Rio 5G case without damaging it so I can replace the broken hard drive?
    I have already tried rapping the back and R-Clicking on the Rio in My Computer (No Hard Drive Found).
    Guru:
  • 155 Answers
Here's a guide for you - sorry but i don't have any photos. If you look in the tips and tricks section for this product then I have previously posted a number of things that may help some of you. If not then send me a request and I will try to sort your problem out.
How to disassemble a Rio Carbon:
  • First take off the front plate (you may want to warm it up, not fry it, with a hairdryer to make the removal easier.
  • Then you will see near the bottom there are two holes which if you get a very small screwdriver then you can unclip 2 of the clips holding the back plate on.
  • Then pry your screwdriver between the back of your rio and the rubber and lever the back off slightly (you may want to get a cocktail stick/match stick etc. to keep this open) then on each side you should see two more metal clips holding the back plate on. Lever each of these clips and the back plate should pop off - don't force it or you might break the plastic.
  • Then you will be able to see the hard drive and the battery below it.
How to remove the hard drive:
  • Make sure your player is turned off and not plugged in.
  • Then carefully lift the drive out of its cradle/holder. It will be attached by a ribbon cable to the main circuit board.
  • At the bottom of the hard drive carefully lever the connector off the drive, make sure you do it evenly so as not to bend the pins if you want to be able to use it afterwards.
  • You will then be have a 5GB Microdrive and a Rio carbon shell.
  • You can then connect up your CF card or new Microdrive.
  • If connecting a compact flash card then you may want to put a bit of foam on top of it to stop it rattling in the case because it is slightly thinner than a Microdrive
Hope this helps you not to break your Rio even more when trying to fix it!
Mowcius
Posted on Sep 08, 2008
..where is this step by step process with photos?
Posted on Jan 04, 2008
  • 752 Answers
Most MP3 players are "snap-together" cases. BUT look for screws under covers or decals first....
Posted on Sep 22, 2007
  • Mitch
    Mitch Oct 04, 2007
    Here.... This is a complete step by step with photos and all. You can't get more helpful than that. So please enjoy, and don't forget to change the rating to "Solved"!!!!!!
  • Mitch
    Mitch Oct 04, 2007
    And P.S. As you will see, My FIRST answer was correct, to begin with! :/
SOURCE:
When I transfer music from Rio Music manager to my Rio Carbon the music manager indicates transfer successful but the MP3 player states no tracks present?
Try to transfer the tracks from the explorer.
1 Connect the Rio Carbon to a computer using the supplied USB cable.
2 Double-click My Computer on the Windows Desktop or in the Start Menu.
3 Locate MP3 or WMA audio files on the computer.
4 Highlight files and/or folders to transfer to the Rio Carbon.
5 Click Edit.
6 Click Copy.
7 Double-click My Computer on the Windows Desktop or in the Start Menu to open another window.
8 In the new window, locate the Rio Carbon (X:) icon that is associated with the Rio Carbon. (X equals the drive
letter assigned to the Rio Carbon.)
9 Double-click Rio Carbon (X:).
10Click Edit.
11Click Paste.
May 24, 2010 | Rio Carbon MP3 Player
Fixing Rio Carbon Wheel
If you look in the hints and tips section for the Rio carbon then it is there... That link works so I am not sure which link you are referring to.
Hope this helps,
Mowcius
Aug 28, 2008 | Rio Carbon MP3 Player
Broken Volume Wheel
Sorry, Rio kinda went bust some time ago so to my knowledge there isn't anywhere that does repairs anymore.
See: Replace broken scroll wheel on Rio carbon for help on how to DIY.
Hope this helps,
Mowcius
Aug 15, 2008 | Rio Carbon MP3 Player
More Rio Trouble >.<
I presume that your computer does not pick it up at all.
Try taking out the hard drive carefully and putting it in a usb card reader. Then if it picks up, format it, put it back in your carbon. Your pc should then pick it up and then reformat it (may be needed) and reload the firmware (from: http://www.rioaudio.com/support/rio/product.asp?prodID=215)
If it doesn't pick up then your hard drive will be bust :(
for less than a 10er you can buy a 1GB CF card and replace it with that (see my post: http://www.fixya.com/support/r590688-replace_broken_hard_drive_in_rio_carbon)
Hope this sheds a bit of light on your problem
Mowcius
May 17, 2008 | Rio Carbon MP3 Player
How to take music off Rio Carbon
I have bad news - I was completely unsuccessful in dragging tracks from the rio to my computer. You can load songs, but you can't "unload" them with the Rio Carbon.
Just in case your computer has capabilities that mine does not, try this:
Double-click "My Computer" on your PC desktop
Double click the Rio Carbon icon
Double click the "Music" folder
Try dragging a single music file from the "Music" folder window to your PC desktop - it will either work, or it will say that it cannot copy the file to the specified location.
Apr 13, 2008 | Rio Carbon MP3 Player
Opening the Rio Carbon to replace the volume button
The easiest and least damaging way to open the Rio Carbon is to start at the bottom of the player and pry it open a little until you can see the tabs. You have to push those to release them. Work you way around clockwise and there are tab a little further into the player, you have to pull the bottom of those out to release them. I did it last night and was able to repair the volume wheel and get the player back together and it works.
Mar 29, 2008 | Rio Carbon MP3 Player
RIO CARBON VISTA PROBLEM LAPTOP
Here is where to get the software for your Rio:
http://www.digitalnetworksna.com/support/rio/
Rio went out of the Mp3 business before vista came around, so you may need to get in touch with Microsoft to find out if Rio can be made compat with Vista.
Feb 05, 2008 | Rio Carbon MP3 Player
Rio Carbon Files
are you plugging it in to the computer via usb? you can click the option to open the folder to view files, and you can delete from there.
Nov 12, 2007 | Rio Carbon MP3 Player
Rio Carbon Repair
I think you should keep looking for another solution, but what i know is that for out of warranty carbon players you can't get it fixed through rio/sonic blue, they will only replace it for a new one/remanufactured one for 99$. Here's a link to a previous post of someone who had the same problem as you: http://www.fixya.com/ThreadView.aspx?thid=101466&prdid=230965 Good luck
Mar 06, 2006 | Rio Carbon MP3 Player
Rio Pearl dropped.
Hi, I found the following info on the Rio site, hope it helps you. They qoute a fixed rate of 99$, i'm not sure it's worth it in your case... maybe you should find a repair person with good hands that can help with it. here's the info : "out-of-warranty returns can be replaced for a fixed cost to you. The out-of-warranty fee for your ­Rio Carbon player is $99. Please note, at this time we do not REPAIR defective or broken units; we will REPLACE them. You can purchase a replacement unit at http://system.s2gstore.com/site/RioAudio/mp3playerssale.htm. For units that are in warranty, this process is known as a ?Swap-Ship? because when the defective unit is returned to Rio by you we swap it for a replacement unit (send a replacement to you). If you are interested in participating in the out-of-warranty program, please reply or contact Rio Audio Customer Support at (254) 299-2759 and we will issue a Return Merchandize Authorization (RMA) letter to you with further instructions. We will need the following information to complete the RMA: · Your complete name: · Your complete shipping address: · Your telephone number: · Your email address: · Model of Rio: · Serial Number of Player: · Part number of player: · Date of Purchase: · Place of Purchase: · Operating System: · Transfer software you are using: · Description of issue and what you?ve already tried: " Good luck!
Jan 05, 2006 | Rio Carbon MP3 Player
Rio Carbon MP3 Player Logo
385 people viewed this question
Top Rio Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
