Question about Fuji FinePix A605 Digital Camera
Cannot change the number of available frames
I had something like 134 available frames until someone put my memory card into their computer, it then reverted to the original setting of 24 frames. I am on a trip and desperatly want to take more photo but my finepix A605 tells me "card full" could someone help? thanks. Jo
  • jo48eagle Apr 23, 2009
    being a biginner i do not know how to reformat the card, sorry.
  • 65 Answers
Reformat the card. Ted10
Posted on Apr 22, 2009
  • Colin Bett Apr 23, 2009
    Go through the menu in the camera until you see format the card.TED10
How do you download pictures from phone to digital frame
Most digital frames require a memory card to display photos. The first step is to download your photos from your phone to your computer. Then you need to put the memory card you get for your photo frame into the computer if it has a built in card reader or into an external usb card reader. Next open the file that has the photos you want, and open my computer and select the memory card folder. Select the images you want and press control and c to copy them, click on the memory card folder and press control and v to paste them. Then remove the card and put it in the photo frame.
Jul 30, 2011 | Parrot 7-Inch Digital Photo Frame (Red)...
I bought a NS-DPF8TR digital picture frame. it came with a Sandisk memory card.I need to know whatthis is for, is it the memory for the frame itself that I download to or what. Also can I transfer part of...
ok where to start..
First of all I do not own this picture frame but hopefully I can help you manage it.
(( I'll explain on how to use the memory card HOWEVER your frame should have a USB cord, which will make this entire process easier. If you would use this cord, then you can simply connect the cord to the computer without using the card reader or the memory card. ))
The Sandisk memory card will hold the pictures that the frame will show. In other words you must put the pictures you want into the card. So the next step is how do you put the pictures in.
I don't know the type of computer you use, but look at your computer to see the small **** where the memory card can go into. If your computer is older or a desktop computer you may not have this. In which case you would need a card reader. A card reader is a cheap item you can purchase in any electronics store. (best-buy, staples etc) It has an opening for the memory card on one end (make sure the one you buy has the correct size to match your sandisk. It should but check it anyways), and a USB on the other end. You simply place the card inside then stick the card reader into the USB port on your computer. On the screen you should be able to see a small box open up called Auto-Play. Basically it is asking what you want to do next. Towards the bottom there is an option called "Open folder to view files" When you click on that a box will appear. This box is basically the folder for your memory card.
Putting the pictures inside is relatively easy at this point. All you must do is to find the pictures you want to put into the frame and drag it with your mouse into the box. (You can also go on top of the picture (or pictures) and click on the right button of the mouse, COPY then go to the open box for the memory card and right click with your mouse and select PASTE.)
Now you have the pictures inside the memory card. (Don't move entire folders instead move individual pictures)
The picture DVD is a similar process. The easiest way is ; place the DVD to your computer, and when it asks you what to do with it, choose "open folder to view files" (if it doesn't go to your Start> Computer> DVD) I would first copy the contents of the DVD to your computer. This way if something happens to the DVD, you will have a back-up. Simply using the same technique we used , put the pictures you want into the memory card. You don't have to put every picture in to the card. Just pick and choose the ones you want.
Hope this helped!
Good luck :)
Dec 23, 2010 | Cameras
I want to extend the extension numbers beyond134. is it possible with Panasonic KX-TDA 200
Not exactly sure what you're asking, so I'll give you 2 answers. If you mean extension number 134, the answer is yes. The whole universe of numbers are available to you and by default you can use 100-599 in a 3-digit numbering plan. You can grow beyond extension 134 if you have the hardware to support it.
If you're talking about 134 physical extensions, the answer is "maybe" The 200 has 11 card slots. Slot 11 is usually reserved for an option board for a message card and other features. Card slot 1 is usually a digital card for digital extensions, and you need at least one trunk card (slot 10?). That leaves slots 2-9 (8 total) for other cards. Each card is 16 analog or 32 digital extensions, so if the system is being used for single line stations, the answer is 128, but if digital you can expand the memory and address more than 128 extensions. Actually, I think you can address 256 ports before you have to expand the memory.
Carl
Oct 30, 2010 | Panasonic Lands Phones
Can someone help me find a way to get my pictures off my sandisk
Try the last 4 numbers of your phone number. Next, take the disk to Wally world see if they can make you a CD.
Oct 17, 2009 | SanDisk 2GB microSD Memory Card
2gb sd card but available only 1gb
levyveress,
Well you have a 1GB SD card, there are roughly 1,073,741,824 bytes max per gig. They vary slightly from USB flash drives it total bytes, but the number should be 1,930 (or something close) MB for the 2Gig SD card, bring it back it may have been mislabeled on the packaging.
randy320sgi
Jan 17, 2009 | SanDisk 2GB microSD Memory Card
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pictures are on camera but wont download
Please use any image editing software to see them. you can use adobe photoshop or something else. it could be help you.
Nov 27, 2008 | Casio Exilim EXZ75 Digital Camera
Digital photo pictre frame wiil not stay on. when turned on it starts and then its shuts down
Check the power supply contacts, if it is battery one remove and put back the batteries, clean battery contact with alcohol.
Sep 12, 2008 | Televison & Video
What kind of adapter do I need to connect insignia NS-DPF7WA-09 digital picture frame through a USB port to download pictures off my computer? Is there as adapter for the Olympia SmartMedia memory card...
According to my research with the information you have posted it should come with a 2.0 usb interface with the model number you gave. I found the product information for the model number you gave here. In case it does not have one, I researched for the olympia smart media memory card adapter and came up with the following adapters. If you scroll down you will see the different types of adapters that will connect via usb port and you can place a memory card in it or some you can connect directly to the picture from your computer. Just make sure before you order you check all the information to confirm compatibility. Hope this help and let me know if you need further assistance.
May 18, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
May 05, 2008 | Cameras
Fuji FinePix A605 Digital Camera Logo
85 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
