Question about Troy-Bilt Chipper Shredder
Transmission oil change.
Troy built rear tine rototiller purchased about 1988. TH-002 was found on engine mount frame. Manual was destroyed in house fire. Need to know the type oil needed........Thank you....Richard Ives
  • Anonymous May 15, 2009
    I received a7horse model k161t need to know what grade oil for engene to use Duane G this was passed down from grandfather & no manual
  • 3 Answers
"ue only G-L 4 gear oil having a viscosity of SAE 85W-140 or SAE 140"
Posted on May 13, 2009
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
May 08, 2014 | Earthquake 6015V Rear Tine Rototiller
I want to Greese the rear tines! there is no oil or greese screw to fill or drain whats the deal
On a troy built rear tines are lubricated by the transmission oil. You will find a pipe plug usually 1/8 in with square head on the side of trans. near wheel axle.
Mar 22, 2011 | Troy-Bilt Garden
MY ROTOTILLER RUNS AND DRIVES BUT THE TINES WONT TURN
Make sure that the clutch doges as I call them are engaging properly. Also check rear tine gearbox for striped gears or sheared keys. To check some of these things it may be necessary to remove rear tine gearbox by removing the 4 bolts that hold it on to the main transmission. Hope this helps.
Sep 17, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
I need a new belt on rototiller.
To replace your tiller belt you will have to :
Take a few pictures before you get started so you know how everything goes back together.
- 1) Remove the belt guard
- 2 ) Loosen the belt pulley and remove spring, remember how this was attached.
- 3 ) Pull the belt through housing and off of the transmission pulley.
Now grab your new belt and install in reverse order.
Feb 02, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Replace belts on Montgomery Ward rear tine rototiller Model number GIL39012B need diagram
Go here and you can download a free manual for your machine.
http://lawnandgarden.manualsonline.com/manuals/mfg/montgomery_ward/tmo39083a.html
Oct 24, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
I need a new motor for horse model, serial no. 360331. which models fit this troy built.
Just about any engine with a 3/4" horizontal shaft that is internally threaded on the end and has the four bolt mounting pattern around the shaft will work. I have gone to Harbor Freight and purchased their 6.5 H.P. engine that is a Honda clone and it will work fine and only costs $100-150 dollars. The only difference is that it uses a metric bolt to hold the pulley on the shaft,the four mounting bolts are metric and you have to disconnect the low oil shutoff or the engine will die when you are tilling deep. It is a good low cost option for the Horse tillers.
Frank
Jun 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Chipper Shredder Logo
399 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
Mike
itsman
ray gallant
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
