Question about Kenmore 24 in. 17022 Built-in Dishwasher
Reset code for sensor in Kenmore 17022 dishwasher
My Kenmore dishwasher stopped working with the green light flashing. The last this happened, the machine was under warranty and the service person came in. Apparently this is a sensor where if the hot water is not at a specific temp, the dishwasher gets into this mode. He input a code (by pressing a series of button in some order). However, he didn't give that code to use. I have the same problem now and am looking to get the code. Can you help provide the code for resetting the dishwasher. Thanks -balvadi-
  • balvadi Sep 24, 2007
    Dylan's first suggestion did the trick. Thanks!
    Sergeant:
  • 279 Answers
I've found conflicting information on this, so I'll post all three solutions - let me know if one of them works. One site told me to push Heated Wash and then Heated Dry alternately 5 times each, in quick succession. Another said hit Heated Wash, Normal, Heated Wash, Cancel. And another (I tend to think this one will work) said to flip the circuit breaker that the dishwasher is connected to off for about 30 minutes. This lets the memory discharge, so it forgets the error message.
Posted on Sep 23, 2007
The green clean light is flashing. It will not go off even when we press cancel. The wash cycle was not completed. The model # is 665.17283400.
The green clean light means that your dishwasher isn't heating the water. Go to the link below to see how to reset the error code and check for reasons that the error happened.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 05, 2011 | Kenmore Dishwashers
Clean light keeps flashing, cant get it to reset. What can I do?
Hi, if the clean light flashes it is indicating the was no rise in water temperature during the water heating cycle. This link below will explain things that could cause it and tell you how to reset the control so you can wash for now. Let me know if you have questions.
Be sure to follow the 'key dance' just as specified'
Thanks!
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 02, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
DIshwasher stopped during wash and won't run or drain.
Sounds like a drain motor startup capacitor, or stuck pump. Try disconnecting power and turn the water pump manually. Some disassembly required. Then after a few good hand spins replug and try again.
Mar 05, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Require reset code for kenmore model 17022 dishwasher
try
Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds)
Jan 04, 2009 | Kenmore 24 in. 17022 Built-in Dishwasher
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 17022 Built-in Dishwasher Logo
358 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
