Question about Sony Playstation 3 (PS3) Console
Problem with ps3 to lcd connection via hdmi cable
My playsation 3 is connected to a philips 42'' lcd via an hdmi cable. been using it for over a year now and everything was fine til recently. i've been having problems with the connection. upon start i get no video signal through the hdmi connection and have to abort to the standard av multi scart connection. i've updated both the ps3 and lcd with the latest software updates and also checked my hdmi cable which is fine. i also tried the ''restore display/video settings'' option but i still get the same ''a connection error with hdmi device has occurred'' message. every once in while the system allows me to somehow change the settings to 1080, but then it flips on me at some point i have to use the 576 av multi scart connection (which totally sucks)...any help will me greatly appreciated.
Thanks.
Did u try another cable?
Posted on Apr 21, 2009
I am trying to connect ps3. (bought may 2012 with uncharted 3). To my denon 2313 via hdmi. No video at all or sound? Please help
You need to tell the PS3 to use the HDMI cable output. To test have you tried connecting the PS3 directly to the TV. Once you have that working then add in the AVR.
Jan 19, 2013 | Denon AVR-2313CI
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
Im trying to connect my playstation 3 to my 42 inch LG lcd tv
When connecting the ps3 to a nice TV like that, you want to use an HDMI cable. You can use the stock red white and yellow plugs to connect to the back of the TV, however you will not get the full HD experience like with the HDMI cable.
Dec 25, 2010 | LG Televison & Video
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    No sound from ps3 when connected with hdmi to sharp lc-42d64u lcd, connected to sony dav-hdx589w via digital optical cable
    on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
    Dec 05, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
    How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
    I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
    Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
    Cannot connect ps3 to lcd tv via hdmi cable
    First off make sure ALL Units using HDMI are Powered OFF! Connect Cable, Then turn on all components. On the PS3 Crossbar (Menu) go to the 2nd column on the left, Then down to Display Settings. Choose Output Settings, Choose HDMI, Use AUTOMATIC. Then do the same with the Audio, HDMI, AUTO Make sure your TV is on the Right HDMI Input! Good Luck!
    Apr 25, 2009 | Sony PlayStation® 3 (80GB) Console
    Ps3-hdmi connection gets cut-off
    Again check setting from the menu of your PS3.
    Do select reset all factory settings....... Hope this will solve an error based on software. But if still problem persists, call your authorized technician for repairing, because there may be some loose contact with your PS3 or LCD TV.
    Apr 20, 2009 | Warner Bros. Interactive Lego Batman
    PS3 not working on 42'' JVC via HDMI cable port
    I have the PS3 and this TV and it works....Try this.
    1. Turn ON TV
    2. Connect HDMI from TV to PS3
    3. Select the correct HDMI input on the TV for the PS3(important)
    4.Turn OFF PS3 if it is ON.
    5. hold [I/O] Power button on PS3
    6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
    7. Configure the HDMI output for the PS3
    Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
    Mar 24, 2009 | Sony Playstation 3 40GB System Console
    Hook up surround sound system to entire system
    Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
    Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
    Sony Playstation 3 (PS3) Console Logo
    226 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
