How do you loud the paper - Office Equipment & Supplies
  • 89 Answers
What printer do you have
Posted on Apr 21, 2009
Model i90. Begins to feed paper then stops and has a loud whining noise
Paper is jammed in the feeder and the loud noise is the feeder trying to do its job.
Apr 25, 2016 | Canon PIXMA Office Equipment & Supplies
My CanonPC940 won't grab paper and push it through to print-also makes a a loud "grinding" noise. How can I fix this?
Sounds like a tire may have slid off of a wheel. Yes they have wheels. Also paper soaks up water like a sponge always keep your paper in the wrapper it comes in and the top side of the paper is where the seam is. Make sure you put the paper in so that the top side is the side going through the machine. I do how ever believe you have a wheel or gear out of place.
Oct 15, 2015 | Canon Office Equipment & Supplies
Canon ir 2420L loud correct size paper how to loud paper
Dear
Pl. check the setting of the copier to the paper loaded(size and orientation), the tray selector switch,paper drive rollers/guide.
thanks
Jan 06, 2015 | Canon Office Equipment & Supplies
Hp 4240n
mechanical check
Dec 18, 2013 | HP LaserJet 4240n Printer
There is a loud clicking sound that comes from the drawer and the paper won't pull through. MFC 8860DN
You can check if the paper guides are set properly by depressing the purple lever on the right front of the tray. The leading edge of the stack of paper should rise out of the tray. If the paper cannot rise, or rises unevenly, you need to adjust the guide on the tray. There should be between 1/16 and 1/18 of play from front to back for the stack of paper in the paper tray.
The loud click sounds alarming, but is not the problem.
Sep 02, 2010 | Brother MFC-8860DN All-In-One Laser...
Loud clunking, then stopping altogether
is the Paper feeding thru if not it could be the paper loader in the paper tray which you can fix by finding a object that will sit in there you could also tape it down this sound like it is the paper loader try this and if not Post back
May 26, 2010 | Brother HL 5140 Laser Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Will not pick up paper. It makes a loud clicking
Check the tab at the end of the paper tray, needs to be right on the arrow for your paper size, too tight won't allow picking up paper. If OK, take out paper tray and set on a table, the gear closest to the table has a flat area that needs to be level with the bottom of the tray or the table. If slanted up you need to bend the paper lifter bar under the front edge of the paper so that the gear is level again.
Jan 25, 2010 | Brother MFC-8460N All-In-One Printer
Keeps saying no paper Makes loud clicking noise
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Jan 19, 2009 | Brother MFC-8660DN 5-in-1 Laser...
Brother mfc-8660dn
try cleaning the tires with alcohol,see if they pick up.
are they real smooth to the touch or do they have a rough edge?
the loud clicking sound maybe a clutch or gear trying to engage and is slipping.
Dec 13, 2007 | Office Equipment & Supplies
23 people viewed this question
k24674
jasbo
jasbo
