Question about Rockford Fosgate Punch 201S Car Audio Amplifier
Can a rf 201s amp push 4-6x9s and 4-104s door speakers
Im trying to hook up a punch 201s amp to 4-6x9s and 4-poweracoustic 104s door speakers
  • 655 Answers
Hello jon_jonmay,
Wiring 4 speakers to each of 2 channels, you will need to wire them series-parallel and run them at 4 ohms. If you wire all 4 parallel, the load will be 1 ohm and the amp is only stable down to 2 ohms.
According to your manual, the 201s will deliver 50 watts into each channel at 4 ohms . So it will be supplying about 12.5 watts per speaker which is about what you get with the average factory radio. They will work OK, but they're not going to be very loud.
Hope this helps.
Posted on Apr 22, 2009
Where does fuse go on punch 201s
there is no fuse for this amp you need to use a cable that goes to the battery that has a fuse
Nov 26, 2010 | Rockford Fosgate Punch 201S Car Audio...
Rockford 201s 600 watt amp turns on but no sound going to the subs and where is the fuse on these?
there is no fuse you need a cable that goes to the battery that has a fuse check you're ground
Nov 02, 2010 | Rockford Fosgate Punch 201S Car Audio...
Need a diagram
you have to take a positive cable with fuse placed near to the battery to your amplifier B+ and a thin wire from the jvc sterei to the amp for the remote REM and an RCA cable for the sound system the negartive wire keep it short as you can and connect it to the chassis
Apr 24, 2010 | Rockford Fosgate Punch 201S Car Audio...
I have everything hooked up just as the schematics say and have sound from my front speakers but nothing from the back 6x9's or the subs?
well let me start by saying your trying to power way to much on this little amp you should be using a 5 channel if you wanna do all that try just hooking up the front speakers and 6x9s
Mar 28, 2010 | Rockford Fosgate Punch 201S Car Audio...
Power/ Ground Problem. Im running a 6ga Power wire to the battery (approx 6')with a 40amp fuse. The amp turns on, then about 10 seconds later blows the fuse. The ground is the same ga wire and is grounded...
1. Start by undoing your ground.
2. Use a jumper cable to hook up the ground to the battery ground.
3. Install fuse and test.
If it continues to blow you have an internal amp problem.
If it fails to blow a fuse you have a problem with the chassis ground.
If it is a ground issue you can chase down the various ground straps and clean the connections or you can run another ground cable to the chassis (body) ground to the battery to reestablish the connection.
Feb 10, 2010 | Rockford Fosgate Punch 201S Car Audio...
No end caps,what are they
The end caps screw on to both ends to hide the cables and wires. Not required unless you don't wat to see any wires in a surface mount type install. Does not affect performance
Apr 29, 2009 | Rockford Fosgate Punch 201S Car Audio...
I wanna know if my rf 201s is ideal for 4-6x9s and 4-104s made by poweracoustic
this is only a 2 channel amp matey soo would only run 4 at the max if you use 2 on one channel and 2 one the other but i wouldnt push it no further then that
hope this answers your question
Upfront Audio
Apr 21, 2009 | Rockford Fosgate Punch 201S Car Audio...
Fosgate 201s amp, high level inputs... where do i hook these wires....
Hello mhjoubert,
On the Punch 201s, the high-level inputs are located just below the gain control. When used to power a sub, most commonly these are connected to the rear speaker wires of your receiver. If the amp is used to power a set of normal speakers, you would connect them to whichever set of speaker wires you intend to power.
Actually, it's probably a better idea to install a low-level converter on the receiver speaker wires and then use the RCA connections for input. This way, you have better control on the input signal, lessen the possibility of induced noise, and do not need to worry about an impedance mismatch causing problems.
You can download a copy of the Rockford-Fosgate manual here:
http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/std_adp.php?p_sid=ZLxer3vj&p_lva=&p_faqid=303&p_created=1083264761&p_sp=cF9zcmNoPTEmcF9ncmlkc29ydD0mcF9yb3dfY250PTEmcF9zZWFyY2hfdGV4dD0yMDFzJnBfc2VhcmNoX3R5cGU9MyZwX3Byb2RfbHZsMT1_YW55fiZwX3Byb2RfbHZsMj1_YW55fiZwX2NhdF9sdmwxPX5hbnl_JnBfY2F0X2x2bDI9fmFueX4mcF9zb3J0X2J5PWRmbHQmcF9wYWdlPTE*&p_li=
Hope this helps.
Apr 11, 2009 | Stingpro ST444 1850 Watts Complete...
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
Rockford Fosgate Punch 201S Car Audio Amplifier Logo
113 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
