Question about Jack Lalanne Power Juicer (Stainless Steel)
No power. Thanx for help.
No power. Plug it in, turn it on = no power. Thanx for help.
  • simplyso115 May 04, 2009
    I have the exact same problem. Gift. It is brand new. Took it out of the box, assembled it, and plug it in... No power at all. I check the assembling so many times; and now I am online trying to find a solution. Help.
Cha-Ching. Finally. I could not sit still until tomorrow to call customer service. For a moment I thought my power juicer motor was shot. :( I was a bit sad. I patiently took apart all of the screw to realized that I only need to unscrew 3 screws on the bottom to get to the motor. Once the bottom part is open I see that one of the cables are loose and just reattached it. It is very simple wiring inside. There is only 3 cable and 3 attachment spot inside...so pretty simple. :) Happy again and Juicing :)
Posted on May 04, 2009
Jack lalanne power juicer mt-1020-1 wont turn on
Hi Have you checked obvious things like fuse or loose wiring in plug?
Jan 01, 2014 | Jack Lalanne Power Juicer 250 Watts
Operations manual required
hi, you can download the user's manual here:
http://safemanuals.com/brand-user-guide-instructions-owner-manual/RUSSELL%20HOBBS
when you go to this page you will find "
List of the top manuals RUSSELL HOBBS (user manual, user guide, operating instructions, instructions for use & instruction manual)
written on the right hand side of the page insert your model number and download it
plz do not forget to vote and click yes if i solved your problem,much thanx! :)
Aug 29, 2009 | Juicers
How do you take the filter and blade off to clean? it came together easily, but having trouble taking it apart...
It should unscrew in the opposite direction that the blade turns. Check the blade direction by momentarily spinning the motor with it's own power (don't touch it!). Once you know which direction it goes, unplug it and turn the blade in the opposite direction to remove.
Aug 19, 2009 | Jack Lalanne Power Juicer 250 Watts
Do not have manual
http://www.powerjuicer.com/pdf/classic.pdf
This is the download site for the Jack Lalanne's Power Juicer.
Jul 20, 2009 | Jack Lalanne Power Juicer 250 Watts
It will not turn on, i tried the reset button still no power. How do i fix it?
Check the plug end of the power cord--if the cord is pulled instead of the plug, it can cause breakage of the wires inside the cord. Try pulling the plug from the cord--if the insulation seems to stretch-out, shorten the cord a little(an inch or so) and install a new replacement plug. If cord seems ok, then an internal inspection of the motor area is the next option.
Jul 11, 2009 | Jack Lalanne Power Juicer (Stainless...
My UNIT-does nOt operate at all.
Hey if you have not gotten this resolved already, here are some things to consider.
I have the same unit. It will not operate is any little thing is left undone. So, I would recheck all of the assembly to make sure all the attachments are properly and securely attached.  The last part to check which seems rather minute, but will prevent the unit from working, is to check that the pulp catcher is securely snapped in. There is a small lip at the bottom that must clik in just right for the unit to kick on the switch is pressed.  Once the metal arm is in place, give it a whirl.... and let see what happens.
Hope this helps..
Let me know.
enov8
Feb 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Juicer will not run
Make sure the stainless bar running across the top is snug on the left and right groove. It has a shut off switch when not installed properly.
Jan 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Power juicer not working
Hi my name is patricia you probably have to have the handle bars on or up so it can be tight and then the motor will run.
Aug 27, 2008 | Jack Lalanne Power Juicer (Stainless...
Jack Lalanne Power Juicer (Stainless Steel) Logo
194 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
dflynn2204
Level 1 Expert
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
