Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
Pool won't drain
The pump starts out pumping the water out and after about 5-10 minutes it stops pumping
  • Samuel Charles Spriggs May 11, 2010
    Is this a below-ground pool?
    When it "stops pumping" is it still running, just not moving water?
  • amanforallre May 11, 2010
    What pump? What pool? What filter?
    Champion:
  • 246 Answers
Must replace motor the cooling fan is damage and the motor is over heating whrn the motor coll down it will start again
Posted on Sep 01, 2009
Machine stopped and bells rang
It sounds like the water pump has seized judging from the noise that you were hearing.
When the water seals become old and worn, water seeps through and ends up in the pump motor bearings, which corrode and eventually fail.
Open the machine up and check the pump, they are not repairable, will have to be replaced should this be the case.
Feb 08, 2016 | LG Dishwashers
Hi, my D3120 Asko dishwasher starts but stops after about a minute. If I press the start button again, it starts but stops again. What's wrong?
When it shuts off, is there still water standing in it? First, you need to know if it stops because the pump (that pumps OUT the water) is working. When it stops, do you hear the water draining? ...(through your sink drain). Many times the tube that pumps out the water is clogged from food matter stuck in the drain tube. If you had a disposal put in recently, there is a plug that has to come OUT of the disposal to hook up the dishwasher drain.
Jan 02, 2015 | Dishwashers
My ice machine manitowoc q 132a starts up stops after few seconds while water pump start
There is a high pressure switch that stops the unit running if a fan fails or the condenser is clogged. Next time you start the ice machine, watch the bottom led on the pcb. It will tell you if there is a fault. Meantime, reset the hp switch and clean the condenser thoroughly.
Sep 06, 2012 | Refrigerators
The dishwasher starts and water gies into the machine but after a couple of minutes it stops. Then a minute or so later it pumps out the water and beeps to show its finished. It does the same thing on all...
What brand have you got? It could be the main spray motor because when the appliance has finished filling it should automaically start the water pumping around.
Nov 04, 2010 | Dishwashers
My water pump stops and starts. the contacts on the pressure switch are closed and voltage is going to the pump. The pump will run for a few minutes but not long enough to reach the 60 # to turn off the...
A lot of these pumps do have automatic thermal switches built into the motor end cap, Double check that its being fed the name plate voltage and that the voltage doesn't drop when the pump is running (which would indicate a loose or bad connection or just undersized wire in the circuit)
Dec 12, 2009 | Plumbing
Dishwasher starts running for 2 minutes then stops
The first 2 minutes of the cycle is a pump out cycle followed by a brief pause then a water fill cycle.Make sure the water is getting to the water valve underneath. Check the water valve for power with a volt meter just after the pump out cycle. No power= bad timer or bad wire. Power = a bad water valve or no water present.
Jul 05, 2009 | Whirlpool Dishwashers
Pump comes on for about a minute...then shuts off..
Has this pump worked at all -pumped water?
When it's running for about a minute, is it pumping water?
Is this a self priming pump or do you need to prime it?
Jun 28, 2009 | Polaris Pb4 - 60 Booster Pump
Hoshizaki ice machine KM500-MAE not sending water to harvest
I would not change the pump. If it runs for 3-5 minutes and stops, it has to be a control. The control board runs the freeze cycle for the first 5 minutes. This prevent "Short Cycling" of the freeze cycle. The board looks at the float after the first 5 minutes for the proper water level but should not effect the pump. If the pump does not run in the wash mode, check out the "Power/ Wash" switch. I would start there before I go spending hundreds on pump motor or control board. You may be able to get by on a $20 fix! Do this and get back to me. We will get it going.
Good Luck
May 06, 2009 | Hoshizaki Commercial Freezer KM-500MAH
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
106 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
