Question about TDV Vison F173 17" Flat Panel LCD Monitor
Monitor turns off and on
When you turn on the power to my Vison 17in flat panel the green light simply blinks off and on and the screen comes on then off at about 1 sec intervals. You can actually see windows booting on the screen one second at a time. After about 15 or 20 minutes it will come on and work for as long as you leave the computer turned on. If you reboot it comes right back on. If you let it stay off for a couple of hours and then try to start it back it starts the on / off problem again. Is this a power inverter board problem or simply a bad on/off switch?
  • alvis_l Apr 21, 2009
    I have taken it apart and all looks fine. Any suggestions on finding out which wire is loose?
You probably just have a loose wire
Posted on Apr 21, 2009
  • roxiemom Jul 11, 2011
    this is exactly what is happening to my monitor. I am going to buy a new monitor cable to see if that fixes my problem. Is your problem fixed?? what did you do??
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
My flat screen wont power on
The monitor should be plugged directly into a wall socket. It has a universal power supply in the monitor that automatically compensates for either 110VAC/ 60Hz or 220VAC 50Hz.
There are a limited number of compatible video resolutions (from the PC's video card) that are supported. The best setting will be 1280 x 1024.
The manual can be found at: http://www.promedialcd.com/001/usa/index.php?page=v1922db
Nov 14, 2008 | Televison & Video
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Vison 19 inch monitor
when you tried it on the laptops did you make sure that you went into the dispaly properties and checkd the extend my desktop on this monitor if nto it wont do anything anyways
May 18, 2008 | TDV Vison F173 17" Flat Panel LCD Monitor
AL178 17in. Flat Panel Problem: Screen goes black after about a second
hi,
I had the same problem before. I open my set to find out the faulty component are at power supply main board.
I change the electrlytic capacitor 680microfarad and a resistor burnt near the FET.
You can visual check first.Color changes and bulky form on cap and burnt resistor easily.
Have a try.
Apr 13, 2008 | Acer AL718 17" Flat Panel LCD Monitor
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Feb 16, 2008 | Computers & Internet
TDV Vison F173 17" Flat Panel LCD Monitor Logo
266 people viewed this question
Top TDV Vison Computers & Internet Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Are you a TDV Vison Computer and Internet Expert? Answer questions, earn points and help others
