Question about Canon PowerShot A75 Digital Camera
LCD is black with camera on, new batteries, etc.
A75-Turn on the camera, no LCD display, it's black. The shutter is open, the batteries are new, I tried a new flash card, nothing works.
  • 3 more comments
  • dregulas Apr 22, 2009
    Thought CCD failure was only an issue in areas of extreme heat/humidity according to online posting by Canon...I'm not in a heat zone.
  • Anonymous Apr 26, 2009
    how do you get a new ccd?
  • Anonymous May 01, 2009
    The screen is black.
  • Anonymous Mar 25, 2014
    Tried turning my camera on this morning after it's been working fine & it's gone from intermittent top LED display, to no results when I try to adjust the shutter speed to simply just dead. Charged both batteries, tried both, tried a new memory card. Nothing. the only light that flashes slightly is the top left blue print button. Gone from working fine to just nothing? I've been shooting on the beach where the camera does most of its work, but i'm really positive there's been no water damage. Can it just be humidity?
    Tried turning my camera on this morning after it's been working fine & it's gone from intermittent top LED display, to no results when I try to adjust the shutter speed to simply just dead. Charged both batteries, tried both, tried a new memory card. Nothing. the only light that flashes slightly is the top left blue print button. Gone from working fine to just nothing? The camera does most of its work on the beach, but has never had water damage, can it just be from moisture in the air or humidity?
  • 538 Answers
CCD is dead. Very common problem.
Needs new CCD.
Posted on Apr 21, 2009
  • pontelemon
    pontelemon Apr 23, 2009
    Well, I fix digital cameras for more then 10 years, and based on my experience, "only ...heat/humidity" - is not quite accurate.
LCD monitor is not working ( the photo taken is not displayed on the LCD screen whereas other details like AUTO, S/L/M, no of photos can be taken are displayed) pl. help
One of two possible things. First try pressing the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. If this doesn't fix the problem...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 08, 2010 | Canon PowerShot A580 Digital Camera
My camera sees nothing. No pic on the screen. Blank. Has good batteries, I can look at old pictures, but when I want to shoot a new pic, there's nothing on the screen. Its as tho a lens cap was on.
If that didn't help, check if your camera is in this list: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a Then see this article.
But if your camera is not listed, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 02, 2010 | Canon Cameras
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
My Canon Sd1000 will not take pictures. You can
Note that your camera does not have shutter priority mode (Tv) as listed in the link. Instead, put the camera in manual mode and turn off the flash, and also turn off the LCD display (press the DISP button). With these settings, try the fix in a darkened room, opening the battery door immediately after taking the picture. Give it several tries, if no luck consider also trying step 5a described in the link.
Dec 29, 2009 | Canon PowerShot SD1000 Digital Camera
Problem with canon a420 digicam
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
No lcd display and no pictures
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 27, 2009 | Canon PowerShot G5 Digital Camera
No display powershot a75
Did you get a solution to your problem? I am experiencing the exact same thing with my A75. Still takes pictures and displays them for the 2 second preview, then back to black. And they download fine, too. But I get the same black screen in every mode except stitch assist and movie mode. Thanks.
Jun 06, 2009 | Canon PowerShot A75 Digital Camera
A75 Turn on the camera, no LCD display, It's black. The shutter is open, the batteries are new, I tried a new flash card, nothing works.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
May 05, 2009 | Canon PowerShot A75 Digital Camera
LCD screen is blank with a purple line on the left side of screen
Its is problem of bad ccd imager and this part will be replaced in your Canon A75 camera.
Canon will repair A75 camera free of cost.
Click Canon CCD Imager Advisory for details.
Mar 17, 2009 | Canon PowerShot A75 Digital Camera
Canon PowerShot A75 Digital Camera Logo
307 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
