Question about Canon PowerShot A640 Digital Camera
Battery cover replacement
The plastic battery cover is broken. I ordered and received a new cover. I cannot determine how to remove the broken cover and replace with new part. Are there any Internet sites with pictorial explanation? Or, can someone explain how to do it.
Re: Battery cover replacement
First, replacement battery covers may be obtained from dealers in the USA - I got mine from San Diego Camera Solution who list the item on eBay. Haven't found a UK outlet, but I guess Leung's at Goodmayes would offer a repair service if you don't fancy DIY.
(Disclaimer that I have no connection with either company).
Not sure what Canon recommend, but the easiet way (worked for me) does not involve stripping the camera down. If you dissemble the old and new battery covers via the three little cross-point screws (see warning), then it is possible to replace the new cover around the original hinge assembly.
The advantage of this method - aside from not opening the camera - is that there are "spares" the bits that will get dropped (spring and screws) so that there is less time wasted trying to find them while effecting the repair!
The trickiest part is the sprung loaded latch, which must be installed with the spring partly compressed. Beware when first taking the covers apart and especially when refitting, because the spring will do its utmost to escape.
Posted on Nov 12, 2009
  • 2,985 Answers
Well you could ask Canon- as they have parts to purchase they should be able to give a replacement sheet. I have not seen one of these - but you may have to split the case- but check Canon first.
Posted on Sep 22, 2007
Where did you order and hoq much was the battery cover?
Posted on Jun 17, 2008
0 characters
3 Points
Camera door thats holds battery small grey latch is broken
Try they might be able to solve your problem. Also look at the latch and determine if it is attached to the front of the camera case or the back of the camers casing I am assuming it is attached to the back then you might consider caling HP back and ordering the Back or Front cover Assembly. Small pieces like this usually don't come by themselves you have to order an assembly, so when when u call for parts ask for Back cover assembly or front cover assembly, which ever it is attached to or apart of. Asking for a perticular piece they will not usually know what you need. You have to talk to them in technical terms.. Hope this helps you out...
Sep 21, 2009 | HP R967 Digital Camera
Need battery door
You may order battery covers in a choice of colors here.
Jan 01, 2009 | Nikon COOLPIX L18 Digital Camera
Battery door.
Hi, waiting for the replacement part, I had a look at the broken one . I think you may be able to replace just the plastic part without removing the pin. I'll look closer when I get the part.
Jul 28, 2008 | Olympus FE-210 Digital Camera
Broken Battery Door
I would think a call to Fuji would be in order: 800-755-3854
They should be able to sell you a new battery cover
Mar 28, 2008 | Fuji FinePix F40fd Digital Camera
Battery door broken
You're making it harder than it has to be. Simply hold the camera in your left hand, and open the battery door so it is standing up. Look closely at the lower left corner of the batterry door. Notice the notch shape. The door plastic door is locked in place by the mating little "L" shape on the hinged door of your camera. Thats all that keeps it from sliding off when you put in batteries. Simply insert a small screwdriver or knife blade in that slot, twist it counterclockwise to push the battery door lock to the left, and slide the door off with no force at all. It's a snap.
Jan 15, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Battery cover for cds6300
the molded plastic clips ,when cover is closed and pushed in to lock are broken from camera body both pieces. How and where can it be repair.
Oct 21, 2007 | RCA CDS6300 Digital Camera
Broken Part - Battery Door
It is not too easy to change the door, but can be done.
You have to "tear" away the rubber from the handle. There are a couple of screws under the rubber to remove. The righter part of the batteryholder is kinda loose at that point. You can use a little screwdriver to open enough gap from right side from the point A. Then you can slide the battery door loose and replace a new one.a298e8d.jpg
Sep 25, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Replacement Battery Cover Assembly
If you're handy, you can replace it in about 3 minutes. Don't attempt it unless you're willing to risk tearing a thin flexible circuit under the rear cover. Looking at the camera from the rear, remove the screws on the right hand side ( 2 ? ) then the screws across the bottom - open the card door, remove the card, and wedge a knife blade between the front and rear cover halves - the card door will be loose with an attached spring coming free. No need to remove the rear housing completely, just enough to expose the tracks for the battery cover hinge. Remove the old door, noting the position of the opening spring at the hinge, by angling one hinge out first. Insert the new battery cover and the card door in reverse order.
Dec 05, 2006 | Kodak EasyShare CX7430 Digital Camera
Canon PowerShot A640 Digital Camera Logo
348 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
