Question about Dell Wireless 2350 Router
Can't get laptop to connect via wireless, works fine hard wired
Any computer I hardwire into my Dell 2350 works just fine. But, when I try to connect my laptop to the 2350 wirelessly, it usually (not always) gets stuck at the stage where it gets a network address. The Wireless Network Connection Status window says "This problem occurred because the network did not assign a network address to the computer". And it says I have "...limited or no connectivity" (I have none). Thanks for any help !
    Problem Solver:
  • 11 Answers
Are you using any encryption on the wireless side? If so, and you incorrectly type the password, that would happen. You may also want to try updating the firmware on that router. From what I was able to find, this appears to be the latest available: http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R96135&formatcnt=1&libid=0&fileid=125402 It's also possible that the wireless interface on that router is starting to go. Especially since you said the directly wired connections work fine. The wireless interface would be separate from the Ethernet, so it's possible for that to be dying out while the other is still ok. That does appear to be a slightly older model router, so if it came down to it you could think about replacing it for something newer.
Posted on Sep 22, 2007
SOURCE:
I just bought and set up a LaCie Wireless Space 1TB as a NAS + router but can't get several computers to connect wirelessly to it. I did get one HP laptop running windows XP to connect just fine. But I...
Is this your first router or you are replacing an existing one with this? If you had a router setup before don't name the wireless network the exact same as your old one unless you go into your wireless properties on all your wireless machines and delete saved profiles.
What kind of security are you using on the wifi? wep, wpa wpa2? If you are using wpa2 and have not updated all your computers to the latest service packs for windows you can have some issues as well. Some routers don't work well with ps3's, try setting the router security to wep and make a ten digit password.
Also the Dell XPS M1530's are known for bad performing wireless cards. You may be able to obtain an updated bios firmware from Dell's website to help fix this though i'm sure it's not the cause of why you can't connect to this router.
See if this helps, if not respond and I will give some more tips.
Chris
Aug 24, 2011 | Computers & Internet
No wireless connection it works fine if it is hardwire
Hi,,,
Need to check your extended wire less range and it should be between 60 feet and do the complete network power cycle and place your wireless near by and try again
Apr 08, 2010 | Dell Inspiron B130 Notebook
I have a dell dimension 4600 which is having intermitent problems connecting to the internet via a hardwire connection to a verizon fios wireless router. The router works fine with my dell laptop both when...
I assumed you adapted the pc with a device for wireless connection ..if all the other are OK ..the problem is this device ......try it on other computer ..if it works ..its just a compatibility issue ..if not its a problem with it ...
also try to change the freqvency they work in ..if it possible ....or change the position ..cause they work on a radio wave and you might interfere with something when it goes out of signal ...
Jun 16, 2009 | Dell Dimension 4600 PC Desktop
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
My internal wireless adapters will not connect to WPN284 wireless
Make sure the default gateways and DNS servers options for both wifis point to your wifi router
Mar 30, 2009 | NetGear RangeMax WPN824 Router
Dell Dimension 2350 wireless connection works / wired doesn't
have you tried replacing the network cable,also try a different port on the router
Mar 25, 2009 | Dell Dimension 2350 PC Desktop
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
I can definitely help you on this, however, this would require us follow a few troubleshooting steps which cannot be dictated here. So, I would request you to initiate a chat session with me from the fixya homepage and we would carry on from there. Cheers
May 15, 2007 | Dell Wireless 2350 Router
Open Questions:
See all Dell Wireless 2350 Router Questions
Dell Wireless 2350 Router Logo
181 people viewed this question
Ekse
Clive
Clive
