Question about Samsung ML-3561ND Laser Printer
Low Life on Fuser error for GCC Elite 21N
I am on my second GCC laser printer.  I retired my last one because it was eating to many fusers.  Now my current machine, a GCC Elite 21N has a fuser error.  The machine counter indicates that I have printed a litte over 25,000 pages.  GCC indicates that a fuser should last about 100,000.  I only print about 250-300 pages a month.  Several questions:   1. What would be the reason for the low fuser life?   2. Are reconditioned fusers reliable?  A new fuser for this machine is about $300. I can buy a new color laser printer for a little over 400.  It doesn't seem worth repairing unless a $150 reconditioned fuser works.  The Tech person at GCC tells me the refurbished fusers are junk and won't work.
  • 624 Answers
SOURCE: Engine Fuser Low Heat Error
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
Posted on Feb 21, 2007
samkong
  • 106 Answers
SOURCE: ML 3561ND engine fuser. low heat error??????
If you have annother tonner cartridge, (the old one will do)fix it and see if it works. If not there might be a component faillure related to the Fuser Unit. Also check for any Jam in the Pinions(Sometimes Samsung Laser Displays wrong MSG.)
Posted on May 06, 2007
  • 883 Answers
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
Posted on Aug 28, 2007
I have the same probolem with the Samsung color laser printer clp-510. I get the "engine fuser low hear error"
What can I do?
How do I get the diagnostic software to try that too?
Posted on Dec 19, 2007
  • 168 Answers
SOURCE: Samsung 1610 Leaser - Fuser Error
Fuser Error is a Fuser Error no matter what the printer is hooked up to.
Most likely the fuser unit is shot and will need to be replaced. Either the heating element or a sensor went bad and will need to be replaced.
Unless you recently tried to run a lot of pages and it over heated.
Then i would shut the printer off, wait 10-15 minutes and then turn it back on again. If you get the fuser error again, then your printer needs to be serviced.
Posted on Feb 03, 2008
Fuser error printer 50.92.11
This indicates low fuser temperature. Likely the fuser has failed. Power off, reseat the fuser and then start again, if error repeats replace the fuser. Be sure to upgrade the firmware on the printer to the current revision as HP has made some adjustments to the DC controller on this printer to extend fuser life.
Nov 09, 2014 | HP LaserJet 600 M602DN Laser Printer - M
I have a elite 12/600 need to change the fuser is there any instructions on how to
You need the "Network Printer 12 Usage Kit", IBM Part No. 63H3111 for 198 - 264 Volt. Number is different when you need one for 110 V. Fuser plus 2 rolls are included as well as a detailed instruction manual on how to replace the parts. Got it for roughly 50 EUR on eBay.
Jul 12, 2011 | GCC Technologies Elite 12/600 Laser...
50.1 fuser error not fixed by instruction on machine; HP color laserject 3500
17 posts - 8 authors - Last post: 23 MarWe are getting a 50.1 fuser error with our Colour Laserjet 3500 printer ... fuser from HP in the UK, but was told that they are not currently available ... hi I have the same problem error 50.1 with two machine 3500/3550 ...
www.fixyourownprinter.com/forums/laser/31146
Dec 04, 2009 | HP Color LaserJet 3500 Printer
Put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
When fuser is hot (10-15 min. or so, print is smeared, has lines through it, and sometimes there is only the suggestion of an image. You can get a good image before the fuser heats up, but density is...
The thermostat on the fuser is failing. Toner requires the fuser to operate at a specific temperature range, too hot or too cold and it begins to stick to things it shouldn't and fall from things is should (like your paper)...in your case the thermostat is not stopping the fuser as it gets too hot. Not only will this eventually cause scoring and melting inside the printer, possibly fire...it means the printer only prints well as the fuser heats up through it's optimum range then you begin to get smearing.
May 07, 2009 | GCC Technologies Elite XL 608 Laser...
Replace Fuser error not clearing
Fuser PM reset
1. Hold the 'up' and 'down' arrows together for 5 seconds or longer.
2. Release the arrow keys and press the 'enter' key.
3. Select '2. Engine' - Then go to option '7.'
4. Go to SP7804-016 (PM Counter Reset>Fuser) and execute. Shows results=OK
5. Turn the machine off and on.
All done.
Mar 20, 2009 | Ricoh Aficio CL7200 Laser Printer
Fuser is bad...actually, the paper jam sensor is bad. can I use a fuser from a different printer
Yes, most likely they do. I don't believe there is much if anything that differentiates one toner from another other then the size of the roller and the shape of the cartridge. If these are the same and given that they use the same fuser, I would definitely try it.
Aug 08, 2008 | Xante Accel-a-Writer 4G Laser Printer
An inch wide streak appears on the right side of a laser printer printed page.
If you can rub the toner off the paper it is the fuser.
fuser, the part of a laser printer that melts the toner onto the
medium. It consists of a hot roller and a back-up roller. After toner
is transferred to the paper, the fuser applies heat and pressure to
ensure that the toner stays on the paper permanently. This is why
paper is warm when it comes out of a laser printer.
For toner problem:
Do a half test as follows -
Print one sheet from the fold down tray, just as the trailing edge of the paper
goes into the printer open the toner door to stop the printer. Remove the toner
cartridge, are the marks on the paper that you can see in the printer? If they
are there the cartridge needs replacing.
Jun 03, 2008 | GCC Technologies Elite 12/600 Laser...
Paper wrapped around fuser roller
http://www.precisionroller.com/fuser-assemblies---units-for-canon-imageclass-d780/products.html
im not 100% familiar with this printer but iv replaced ALOT of parts on ALOT of different types of laser printers(color and mono) the fuser invariably will come out either the left or the right side, last place would be the middle. either way they are always fairly easy to get to being they are the second most common part replaced in a laser printer. Tipicly located right by the toner in the paper path. this should be easy to find.. IF you still need help finding it send some pictures with either side taken off or the "hood" up. and ill point it out to you. BE CAREFUL OF the contra wire. it will zap you.. even if the printer is unpluged.
Jan 22, 2008 | Canon imageCLASS D780 All-In-One Laser...
Samsung ML-3561ND Laser Printer Logo
242 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
