In adequate picture quality
The picture seems to be good when I watch TV or DVDs but I lose quality when I switch to VGA mode for my computer. Can you suggest any solutions? Are there drivers I need to load. Does the color profule need to be installed? HELP!
    Novelist:
  • 177 Answers
Try Upgrading the drivers for your video card.
also you may need a better video card for larger lcd displays/tvs, etc....
Get at least a 512mb Nvidia Video PCIexpress card.
That'll do it!...
also check your display settings and color settings first.
Posted on Apr 21, 2009
Hi there, i have a goodmans GTVL19W17HD T.V connected to my computer and and the back of it there are VGA AND HDMI connectors and my graphics card has a vga but it doesnt have a HDMI Connector, but if i...
VGA quality only. If you want to release the high definition features of your TV, use high definition
graphics card together with HDMI cable. Hope it helps. Good day!
Sep 02, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
55lw5600 3d not working correctly. Put the tv in 3d mode and the pictures do not line up correctly.
Try to wear the eyeglass for 3D and, that is the effect of 3D mode. good day sir
Aug 21, 2011 | LG 55 55LW5600 3D LCD TV
I have an LG 42lh30 I bought less than a month ago from frys. When I opened the box it did seem slightly used maybe it was returned and refurbished or something. I have an xbox and I use a philips 1080p...
Is it a Duplicate Question....Wonder why?
Same reply :0
This is an internal Fault. Diagnosis is required to make sure whether it is Failed T Con Board or Light Engine. I do not think that it would really help by changing the TV settings. This was a Common Problem with Old LCD's where you got Blurry Spots specially while Playing Real Fast Movies or Games. On Few Occasions, it as Corrupted Firmware.
As i cannot see the Video or Screen from here, more likely what i could guess it is an Internal Fault as you have tried using HDMI, Use different Setting Combination's and you got the same Picture Quality with DVD as well.
So, what i could suggest, get back to the Seller and Lodge an Official Complain and get it Replaced. There is no point in Opening and TV and Inspecting it and Replacing Components when it was less than a month ago.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 30, 2010 | Televison & Video
Inadequate Picture Quality
This my be a problem with your video card drivers or the card itself. Try updating the drivers for both the video card and the drivers for the television at their websites. Also check all your cables to make sure the connections are good and the cables are working fine. Try using contact cleaner and a small brush to clean the contacts on the cables and connections. Spay solution on the brush and only clean the connections when the units are turn off to avoid shorting out the connectors. Allow a period of time for the contact cleaner to dry before reconnecting to the units . If all this fails, contact customer service for help with you problem. Hope this helps you with your problem.
Apr 21, 2009 | Insignia LCDTV26 26 in. Television
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
I am trying to connect my PC to my TV. I have a Sharp HDTV and my PC is a Toshiba with windows XP. I have a componert video cable which is connected to the TV and PC. I have used Fn and F5 didn't work....
what model of TV was it please,
Does your computer have tv out video card installed?
For video to tv you will need a vga to tv converter,this is an external device and will work on the computers vga output straight into a vga input and give you 1 x vga out,1 x rca out, 1 x s/video out,comes supplied all prebuilt with onboard graphics solution. no extra power required runs straight of vga output.
Once the computers video output is established then set the TV up to tune into the converters output signal.
HD TV can be set up to run thru rca and components and if model is late enough shuld come equip with serial vga input for computers.Other than that HDMI seems to be the better quality of picture over rca component.Cost verses dollar really and function.
Cheap fix VGA to TV CONVERTER
Expensive Fix HDMI to HDMI
(it is posible to hdmi over cat5e)
NO COMPARISON FOR QUALITY.
Jul 10, 2008 | Acer Aspire 3680 Laptop
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
