Question about Maytag Performa PAV3200
Washer wont agitate or spin
Mod # PAVT910AWW Washer has been very off balance lately. Replaced the belt. Washed one load and perfect. Washed another and spin cycle didn't remove all water. Loaded another thinking maybe would work properly again and heard a really loud popping..clunky noise and then nothing!. Now it will not spin or agitate at all. I hear the motor running still. What steps to take next. Please help I have a load of clothes with bleach sitting in it!!!Thank you Shelly
  • smbentley99 Apr 22, 2009
    Thanks you for the reply..but before I called the supply parts company I checked one last thing. I held the lid open and started the spin cycle with a screw driver. The spin cycle works fine with a heavy load of jeans. If I have light items and it gets off balance the washer starts walking then I know it wont spin all water out.So..I think the spin cycle is good it just wont agitate. So does this mean my transmission is good still? Do I just need a new agitator part? Thank you Shelly
  • 77 Answers
Sounds like your transmission is going bad. usually they will pop the belt when going out. Probably with a service call and the cost of the transmission, you'd do better heading to sears. Sorry to bear the bad news. Good luck.
Posted on Apr 21, 2009
I washed a load of clothes and the washer worked perfectly until the last 3 minutes where the washer does the final spin and all of sudden smoke pours out of the back of the washer and when I opened the...
well is it a smell of burning rubber? maybe the belt that turns the drum has got jammed. over time these belts get loose and when a full load of clothes are washed the belt slips creating heat hence the smoke..hope this helps..
Dec 04, 2013 | GE WSXH208A Front Load Washer
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Does sound like it's not balanced properly, or maybe it's set on drip dry instead of spin , basic solution i know but often the best lol ,
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
I accidently washed a large load of laundry without switching from previous small load selection; now washer has burning smell and wont work??
probably broke the motor coupling, it's made of rubber and plastic,when machine is out of balance it breaks, if you turn it on agitate or spin and you can hear the motor running but nothing spinning then it has broken, part cost about 20 bucks Try Repairclinic.com
Jan 31, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
Will not spin or agitate
Get the model number. It may have an off balance switch that is stuck. Try moving agitator like its off balance and then turn on.
May 18, 2009 | Washing Machines
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Washing Machines Logo
287 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
