The picture seems to be good when I watch TV or DVDs but I lose quality when I switch to VGA mode for my computer. Can you suggest any solutions? Are there drivers I need to load. Does the color profule need to be installed? HELP!
This my be a problem with your video card drivers or the card itself. Try updating the drivers for both the video card and the drivers for the television at their websites. Also check all your cables to make sure the connections are good and the cables are working fine. Try using contact cleaner and a small brush to clean the contacts on the cables and connections. Spay solution on the brush and only clean the connections when the units are turn off to avoid shorting out the connectors. Allow a period of time for the contact cleaner to dry before reconnecting to the units . If all this fails, contact customer service for help with you problem. Hope this helps you with your problem.
