Question about Kenwood KVT-512 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
Cant play dvd but can here the audio how do i bypass
  • 10,594 Answers
That is safety feature that Do Not Watch DVD Picture While Driving.
You can bypass that feature at your own risk.
There is Wiring Harness at back of unit, find Light-Green wire in that harness, disconnect it from parking sensor and connect it to car body / dvd player body/ ground or join it with black wire of same harness.
You will see another harness at back of unit that has few RCA jacks that is input/ output harness and no need to touch it.
Below is an image of back of player and light-green wire is marked...
Hit "add a comment" button for further query / info.
Thanks.
Posted on Apr 21, 2009
SOURCE: how do i bypass the parking brake switch in order for my video to play
none of this works for the uv7i...anyone got a code? except rerouting the pink wire.
Posted on Sep 17, 2007
  • 10 Answers
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
Posted on May 19, 2008
j_del
  • 1586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 24, 2008
you need 2 toggle switches . yello/blue wire to switch - switch to ground.
yellow/black wire to switch- switch to red ing. wire. turn this switch on and pulse the other(yellow,blue) 3 times and leave on, then turn the other switch off and then you can ride and watch dvd. just did it this morn. QTRHRS
Posted on Sep 19, 2008
yea it will work if u leave the car running but once u shut off the car and turn it back on it doesnt work there has to be another way
Posted on Nov 16, 2008
I think the wire that should go to your hand brake is green, all you need to do to bypass this is hook it to an earth.
May 06, 2009 | Clarion MAX385VD Car DVD Player
Take the wire that they tell you to hook to your parking brake and hook it to ground instead.
Feb 27, 2009 | Pioneer Car Audio & Video
i have heard that many of dvd players have an extra wire and instruction manual tell's to connect it to something relaited with parking break (then you hold parking breake it gets ground and completes circut so video starts) so you can connect it to and ground wire with a swich becouse of that you can simulate paking break :) hope it will help :) i have the same problem but just haven't got time to test this :)
Jan 04, 2009 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
ITS just a ground cable hook it to the radio ground i did and mine works fine
Aug 21, 2008 | Jensen's VM9312 Car DVD Player
May 15, 2008 | Car Audio & Video
Ground the handbrake wire to the outerpart of the "line out" connector if it's not in use, works a treat
Apr 29, 2008 | JVC KD-AVX11 Car DVD Player
N1 internal solder bypass to work with newer software, N2 solder the two connection under the silver sticker(might void warranty), N3 switch the switch under the silver sticker(might void warranty). Goodluck.
Mar 31, 2008 | Pioneer AVIC-N2 Car DVD Player
Feb 24, 2008 | Alpine IVA-D310 Car DVD Player
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
Feb 18, 2008 | Dual XDVD8181 Car Video Player
Kenwood KVT-512 Car DVD Player Logo
1,001 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
