Question about Lowrance Lcx 28c Hd 7" Gps Fish Finder Combo With 200 Khz Tm Transducer
Unit will not power up
My unit will not power up. All the fuses and connections are ok
I too have lowrance unit which is the reverse. it is powering up by itself as opposed to not powering up,despite checking fuses/lines which are ok. If you are lucky enough to be under warranty, take it back. If unlucky, you too, like me have paid big bux for something that has perhaps lasted only a few years and should last a lot more, given what you perhaps paid for it.
Technical expert advise is that initially the unit will power up by itself but now has progressed to not powering up.You may have a problem with the keypad failing. the bubble type press pad. The wiring shorts and the unit jumps voltage across the keyboard which "tricks" the unit into thinking that you have pressed the power key. After a period of time the unit problem will just progress to not powering up at all. basically the unit has ulitmately failed with time. Short of perhaps definitely stating the unit hasnt been hit or dropped, i suggest if you are in Oz, contact lowrance service in Sydney who are happy to help. they have a possible solution whereby you send in the unit, and they check it.
Generally if not deemed repairable they will replace it with a new similar unit. the only catch is you are up for X (few hundred dollars). this might seem a bitter pill, but you are only charged about a third or half of what a new replacement unit would cost. they give you an updated current model similar to what you have. Im prepared to take that option as it is a cheaper alternative to starting again and paying top dollar. Ive never experienced a power up/down and short of yelling at my son thinking he was playing with the unit, i will have to eat pie and realise with these sort of temperamental gadgets they can fail in the un normal way. Hope it helps. Kahuna 430
Posted on May 11, 2009
No power to my sceptre e325bv-hdh. no visible damage or loose connections. need ideas on what to check and or replace. working on it as a diy project
First check that AC is reaching the Power unit with a meter.
then check that DC is coming out.of the power unit.
If it isnt reaching the power unit then its the ac cable or fuse.
If it is reaching the power unit but nothing out on the DC side
then its the power unit. If DC is there then a fuse on the board may be the problem, If ok then look for any burnt components. Make sure the TV is unplugged from the wall socket though. Be careful there are voltages that can kill!
Jan 28, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Fault code 049f,this fault shows on hard wired controler connected to high wall unit?
f-049 Check power supply voltage to the outdoor unit is correct (1ph ?220 Vac ±10% or 3ph ?380 Vac ±10%). If OK check fuses, if fuses OK, replace outdoor main PCB
Dec 10, 2010 | Heating & Cooling
I have a printer epson stylus c45 and the problem is no power what will i do please help me
If it doesn't power up completely and you are sure the power source is ok, then your unit most probably has a faulty power supply unit. it could though be a simple blown fuse. you will have the unit opened, inspected and if fuse ok, then replace the power supply unit.
Nov 22, 2010 | Epson Office Equipment & Supplies
Bosch KTR18424 Compact Refrigerator completely dead no display either fuse in plug ok
ok unit is dead . ck the power at the plug first . if ok then look for a bad connection to ref .. there is no fuse in the unit to prevent it from working . some times they do get stuck in defrost cycles and is so repl the A D C .. hope this helped mm.
Jul 22, 2010 | Bosch KTR18424 Compact Refrigerator
Dead
I am assuming that your unit cannot be powered up at this time. this is the result of a failed fuse or power supply board. remove the cover and check the in-line fuse(if equipped). if the fuse is OK, replace the entire power board. Now, if you unit isn't equipped with a fuse, you will need to check the solder on the power cord. make sure it is soldered on the power board correctly. if its not loose and, it is connected securely to the power board, replace the power board.
Jun 04, 2009 | Panasonic Audio Players & Recorders
THE COMPUTER IS NOT WOKING
Check the power cable/cord for continuity with your multimeter ok. Make sure also that the mains or power outlet is giving the right voltage. This is also done by the use of the multimeter - either analog or digital - any one at your disposal can do ok. if all work well, then the power supply unit should be removed from the system unit, connected directly with the power cord and then bridged. That is at the secondary output which connects to the system motheboard. Locate the power-on cable(normally green in colour) and bridge it with any black cable on the same row. The cooling fan at the back of the power unit should be rolling if the unit is ok. Good luck
Jun 03, 2009 | Compaq (243890-001) 250-Watt Power Supply
Copier ricoh aficio 450 error code SC 542-00 ?
  • SC542: Fusing temperature warming-up error
  • check the fusing unit -
    The fusing temperature does not reach the fusing standby temperature within
    125 seconds after the main power switch is turned on.
    - Possible causes -·
    Fusing thermistor defective or out of position
    · Fusing lamp open
    · Fusing thermofuse open
    · BICU defective
    · Power supply board defective
    · Poor fusing unit connection
    troubleshooting
  • to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres ok
Mar 18, 2009 | Minolta EP4000/5000 CS/PRO Copier
Machine will not power up
power out let ok ?
fuse on the power cord ok ?
if all ok then it could be the internal fuse in the power supply unit
dont try and replace it you need a new 1
Mar 24, 2008 | E-Machines eMachines T3830 PC Desktop
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Lowrance Lcx 28c Hd 7" Gps Fish Finder Combo With 200 Khz Tm Transducer Logo
491 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
