Question about Dell Dimension 2400 PC Desktop
My two CD ROM Drives won't work on my Dell 2400. Drivers appear fine but says it cannot find device. Gives a code 41. What's happening?
  • rockytopham Apr 22, 2009
    Fix worked great, CD drives are working again.
Please call dell support
1-800-624-9896
Posted on Apr 24, 2009
  • 123 Answers
Go here
http://support.microsoft.com/kb/314060
and click the Fix It logo
Posted on Apr 21, 2009
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
I was just given a Dell Dimension 3000 by my daughter, who said there was no problems with it. It has a CD-Rom drive and a DVD-RW drive. When I power it up and click on MyComputer, neither of these drives...
They probably can't load because they are loading at the same time and XP can't sort it out.
Remove the cable from the CD ROM and re boot but enter the BIOS and make sure it is no loonger there.
The nachine should load the DVD rom.
You can try adding the CD rom now, it may work but being XP it may grab the wrong driver again and hang up.
Download new drivers from Dell.com
Hope this helps.
Jan 02, 2011 | Dell Dimension 3000 PC Desktop
COMPUTER CD PLAYER WONT READ PLAY OR BURN CDS
Is the device detected in Device Manager withour conflict? Go to Control Panel, click System, Hardware, Device Manager, and click the + beside DVD-CD-Rom drives. Locate your drive, right click and select unistall, then reboot. If if does not work after reboot, try updating CD Firmware from http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=gen&catid=&impid=&os=WLH&osl=en&SystemID=DIM_PNT_P4_CEL_2400. If not, you may need to replace the drive, if you confirm the IDE cable is connected and working fine.
Jan 10, 2010 | Dell Dimension 2400 PC Desktop
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Dvd and cd rom code 41 erreor
The driver is corrupt, un and reinstall it. To uninstall go to control panel and then add/remove programs.
Oct 20, 2009 | Dell Computers & Internet
My computer wont let me install OS
You have to reboot and tap F2 to go to BIOS select option to enable the Secondary controller and to detect the proper IDE Devices?
Also make sure the IDE cable is firmly attached and the you have pin 1 alligned properly at all 2 (or3) connectors. And if you have 2 IDE devices attached make sure one jumper ( in HD or CD ) is set to master and the other to slave.
If none of this works, try a known good CD rom drive that you can try and try switching with a known good cable.
Once the system recognize the CD ROM youre set to go !
Jan 04, 2009 | Dell Dimension 2400 PC Desktop
Both Drivers for CD Roms wont work for Dell Dem 2400
The two devices are both hooked to your secondary IDE channel. It could be that the IDE controller driver is corrupt or missing. Go to the Dell website, download and reinstall the CHIPSET driver, which includes the IDE channels. Then reboot. The driver page is here:)
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Failing that, verify that the drives are visible in the BIOS setup. When you restart and see the Dell splash screen, press F2 to go into the BIOS setup, come down to Drive Info and see if the model is reported for the two opticals. Perhaps it got disabled there, but not likely unless you were changing settings.
Another possibility is whether you removed and CD/DVD recording software recently (Sonic, Roxio, Nero) as these may have changed the registry entries related to your CD/DVD drives.
If nothing works, please post the specific error code reported by the Device Manager. Right click on each drive in the Device Manager and it should be listed in the device status box.
Dec 31, 2008 | Dell Dimension 2400 PC Desktop
CD rom drive not working
sounds like it's gone home early. replacement will do the trick..
Mar 06, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Dell Dimension 2400 PC Desktop Logo
207 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
