Question about Toshiba 32AF41 32" TV
No sound from 5 yr old Toshiba
Bought my Toshiba in Dec, '01. All was GREAT until 2 weeks ago... no sound. Dead. Stil had picture but no sound. Volume control numbers would raise and lower but no sound whatsoever. Checked 'mute' button ... no change. Checked if it was cable signal... cable worked on another tv.
  • akidof60 May 01, 2008
    Same exact scenario, except my TV is a JVC AV-27120. I also tried a different tv with the same cable box, and it worked fine. Is there a separate fuse for the audio section of the TV?
    Problem Solver:
  • 8 Answers
This is also a tough problem but certain solutions may help,try these steps:1. try using a dvd or any player that would connect to your t.v. and switch to VIDEO mode,if that does'nt help... 2.check the speaker,if good; try resoldering the sound i.c.,if nothing happens, try replacing the sound i.c. it may be defective.and the last one have the t.v.'s memory i.c. be reprogrammed by technicians who have the right tools of reprogramming t.v.'s memory...
Posted on Sep 22, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As picture is ok means 100% it is due to sound section. solution 1 check speaker &its connection or loose 2 check supply to sound section 3 check parts in sound section (resistance& capacitors). 4 check for audio ic if it is demaged.
SOURCE:
I have a 4 yr old philips tv with sound but no picture, any easy solution?
I need to know model number to assist you--way too many different sets.
Mar 11, 2012 | Televison & Video
LG 19 LH 2000 no picture or sound
i have exactly the same problem and my tv is just 2 weeks old !!
any soloutions?
Nov 21, 2009 | LG 19LH20 19 in. LCD HDTV
Sound but no picture
U change ur bulbs lately,might need new bulbs.
Sep 22, 2009 | Televison & Video
Watching dvd, great pictue and all of a sudden black out
7 Blinks is the failure of the SC/SU/SD PCB's (1 2 or 3 depending on how lucky/unlucky) you are.
Panasonic have a great warranty usually. Give them a ring, it has failed.
The flashing LED is the fault code.
Sep 06, 2009 | Panasonic TH-42PZ77U TV
Same problem, vizio 47" LCD TV, six month old
change out the LVDS cable (the cable that go from the control board to the main board) and it should resolve your problem. If your TV is still in warranty, call 1-877-MY-VIZIO and they will set up an in home repair for free.
Jul 01, 2009 | Vizio VO47L 47 in. LCD TV
Light engine
where are you getting your parts from? sounds like someone may be selling you used parts to get more business.
Apr 15, 2008 | Toshiba 62HM95 62" HDTV
No picture
57H81 57 in. Rear Projection Television Go to above unit for tip on your problem.
Jun 22, 2007 | Toshiba 55H70 55" Rear Projection...
No picture but have sound
Toshiba 57H81 57 in. Rear Projection Television Go to above under solution for tip on fixing your problem.
Jun 22, 2007 | Toshiba TP50H50 50" Rear Projection...
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 32AF41 32" TV Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
